No problem. I know sometimes the EPC can be hard to find parts in, it helps to have a second set of eyes look.
Doat;2017735 said:anyone know where I can get a 7MGTE intercooler hard pipe kit without a flange for a BOV? Seems like every kit I come across either has an intercooler with it or the pipe kit has a BOV flange.
A-to-the-J;2016670 said:Can anyone please tell me what clutch disc this is?
Sent from my SPH-L720 using Tapatalk 4
3p141592654;2018077 said:For column surrounds, looks like there might be a difference between A./T and M/T. There are three part numbers for 89+. Pre 89s were all the same except for color. Post 89s are all black.
3p141592654;2017937 said:Rear wiper shares fuse with front wipers. Not sure what you are calling the relay box. Other than the switch, everything is in the wiper motor assembly. You should see 12V on the blue wire going to the wiper motor. Grounding either of the other two wires (light green/red or light-green/black should cause the motor to turn.
grsupra87;2018001 said:Small question. I have an 89 5 spd. When I bought the car, the top steering surround piece was broken/missing over the ignition switch. I have since bought two different sets of column surrounds, both from 89's like mine, but they don't fit right? I know there were changes year to year, but were there changes mid-year? At least now it's not broken, but it sits 1/2" off. Can someone educate me? Search function was not much help.
Doat;2018770 said:Is there a guide on fixing the hatch leak? I replaced the stripping around the inside of the hatch but I am still getting leaks from under the interior panel.
