from page BR7 of the TSRM "begin bleeding air from brake or wheel cylinder with longest hydraulic line"
next comment: "repeat for each wheel". It is safe to assume you'd want to bleed the cylinder with the next longest line.
If you look at the lines, the brake tube to the back travels down the left side of the car, making the rear right the furthest.
Next furthest is the rear left.
The front left line goes from the ABS cylinder back over the trans tunnel, making it the next longst
The front right line goes from the ABS cylinder directly into the wheel well, making it the shortest.
Happy now?
