I have one of these. Here is my experience so far.
Important notes, JDM ECU with an EBC, stock 7MGTE, divorced BIC DP, 3 inch cat and HKS dual tip exhaust.
-In 3rd gear, boost starts building at 3500 and hits hard by 4k and then pulls all the way tillredline fuel cut.
-Hits fuel cut at 9-10 lbs.
-Without EBC, ie just wastegate, terrible response and not much power. But, no fuel cut!
-The compressor housing is very close to the exhaust manifold heat shield. In my application, it has burned the silicon intercooler piping coupler at that spot.
-Exhaust studs on the turbine side are small.
-The previous owner claims he put 25k miles on the turbo so far.
I clocked the compressor slightly so it clears the exhaust manifold and so the intercooler piping has an easier pathway. This did make it so the wastegate actuator would not connect to the wastegate itself... so I did the ghetto thing and just bent the actuator arm so it connects. I have yet to run the 7M with this setup, but I'll let you know how it goes.
Hopefully later this year, the standalone will get installed and I'll get a chance to push this turbo a bit more.
