T4 Turbo oil drain into Pan ok?
dbsupra90
toonar
indiucky
IJ.;1432356 said:
if you impede the drain in any way shape or form will flood into the Turbine housing and smoke like a bitch.
suicide
86
Barrie , Canada
so it looks like i might have to go with a different manifold...
unless anyone know if i can run it inline with the oil filter relocation kit????
Did you think this post through?
seriously think about it for a few minutes then come back and tell me why it's wrong.
suicide
86
Barrie , Canada
i guess i didnt really think it through very well... i was thinking as long as its on the return side of the filter might work... but i guess no matter what its under pressure
suicide
86
Barrie , Canada
Mr. Y;1433282 said:
sorry for small offtopic, what exhaust manifold is it? I'm going GT4202 soon and looking for something better than mine chinese mani for 150$.
Thanks.
it is an even cheaper manifold also from china, i dont know who makes it i got it off someone local in Toronto, Canada.
suprafanatic
1,607
Greenwood, IN
I ran into alot of fittment problems when i went with a T4 setup also.. do they even make a proper manifold and an exact bolt on oil drain line that both fit our cars? Or do we just have to make things fit ourselves?
dbsupra90
toonar
indiucky
Thanks.
buddy bought the manifold for a 2j (the chinese) and cut off the collector section. another buddy water jet cut a 7m flange and from there welded up piping to fit it together. you aren't going to find an off the shelf manifold to fit a gt42 on a 7m. i can help you source the pieces to build one, but from the states shipping might be a little high.
nate- the sp manifold fits well from what i've seen. its far from $150 tho.
