T3 tubular manifold
JDMMA70
2,550
Houston
Does anyone make a t3 manifold now a day for the 7M? I know blitz and greddy did at one point. Im looking to go external wastegate on my 20G and would like a tubular manifold to make things easier. Hoping to get suggestions and ideas if you have any that conform with my goal.
Thanks
Albert
May 13, 2009
1,710
Tempe, AZ
To high for what exactly?
Most Ebay manifolds sit to low IMO. and if you run a turbo with a T04s housing youll have to space it up anyway.
JDMMA70
2,550
Houston
I plan on running my TD06H-20G im just a little skeptical on getting a manifold and spacer that im not sure will fit if you know what I meab
Albert
May 13, 2009
1,710
Tempe, AZ
Well I doubt that, If my buddys 7mgte with a t4 tubular, with spacer. on a T67 turbo, and it fit for him (hood closes?) Pretty sure the little 20g will fit.
Albert
May 13, 2009
1,710
Tempe, AZ
I think youll be fine running a t4 mani, with the adapter. I put my "seal of approval" on it! lolz
Plus later down the road if you plan on getting a T4 based turbo, adapter comes off, bigger turbo goes on, then all you have to worry about is downpipe, and charge piping. (easy to fix IMO)
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Do you have an adapter on your stock manifold to run that 20G or is it a bolt on deal? There are T3 adapters with waste gate flanges on them on eBay. Friend ran one on his car temporarily. Think he only paid like 40 bucks for it. If it's a bolt on, you could get an external gate welded to your stock manifold like Devin LeBlanc did.
