Suspension Lean
jessetooslow
551
Tiverton, R.I.
Ever since I put my H&R springs in I noticed it leans very little to the drivers side, you can barely notice it, but its just one of those things that aggravates me, I stil have the stock shocks in, could that be the problem? or is it a broken suspension piece?
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
I notice that on my car too. But i have tokico illumina's for the front and HP for the rears and still i get that "lean" for the driver side. It is buggind me and i want to know what is wrong but putting it on the lift doesnt really do anything.
jessetooslow
551
Tiverton, R.I.
here are 2 pics, one of the front one of the back, you can notice it more from the back, why would it be doing this?
SupraMario
I think it was the google
The Farm
Im going to go with you stock struts are gone...If you just did springs..Thats my guess.
And yea that is VERY VERY noticeable from the back and would bug the ever living shit out of me.
SupraMario
The Farm
jessetooslow;1106165 said:
thats what I figured I should be getting to shocks real soon, I'm gonna get the TEMS compatible Tokico.
You should be able to just go to the front of your car and push down on both sides and tell which ones is less resistant. That drives side looks like its going to bounce around like a civic with cut springs.:biglaugh:
iwannadie
981
gilbert, az
I have a similar problem, my rear pass. side is higher than the other corners. I can get 3 fingers tightly between each fender/tire except the rear pass. I can get 4 fingers easy between that wheel/fender.
I have eibach/tokico blues and they been on for a few years. I just recently noticed the problem. I can push on the rear corner and it doesnt bounce, it reacts the same as the other 3 as far as I can tell.
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
It seems to me that the condition of the shocks shouldn't affect ride height since the shocks do not offer enough resistance to support the vehicle.
A more likely suspect would be springs, bushing wear, tweaked or maladjusted suspension components. On an older car like the Supra I would first look for sagging springs and worn bushings.
SupraMario
The Farm
He said he completely replaced his springs though.
I'm with SB on this shocks have no effect at rest.
Swap left springs to right side, while you're doing it compare the free lengths.
I always install the longer front/rear springs in the driver side if there's any difference.
Also check the spring seats while it's apart the pass side ones may have some crap under then making them higher up on the shock.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
my last supra leaned, at least i think it did... all new bushings up front and everything. brand new springs too. new struts.... never bothered me that much though.
suprabad;1106435 said:
That's why I also mentioned "worn bushings and/or tweaked/maladjusted suspension components". Short of a bent subframe there isn't much else it can be.
If the bushes on one side were tightened without load it would do this.
(it's also tear the centres out of the bushes eventually)
87witmoreboost
Officially HKS'd
Aug 27, 2007
323
New Hampshire
As many have said, the shocks have nothing to do with this. Shocks only affect the dynamics of the suspension, not the statics. Springs compress based on force applied, shocks limit the velocity at which they react.
You could have 4 stock TEMS that were blown to nothing on H&R's and that car would sit the exact same a 4 rock-hard Koni yellow's on H&R's.
Unless you captured something large under the spring seats (very large), you better have the bushings checked and/or linkage adjusted.
