suprra_girl's rebuild ;)
J
JerzeySlowpra
Guest
would it matter that the exaust manifold rides so close to that? wouldnt it make the oil hotter then it shuold be when going into the filter, or does that not matter probley
J
JerzeySlowpra
Guest
yeah i guess your right, if worst comes to worst it can be heat wrapped, i think im gonna attempt taking it off tomorrow and taking a grinding wheel to it, i've been reading alot on oil filter re-location and it just seems like a pain in the ass, not so much the oil relocation itself but getting an oil cooler adapted into the system like the stock housing does, so i'll see how it goes and let you know
williamb82
907
4
Tampa, Fl.
JerzeySlowpra said:
how does your SS manifold not give you any problems with the oil filter housing... mine does, i need like an oil relocation kit or something to make it work
the design was revised. the ones that have problems were first run units. the new ones dont have that issue anymore.
william
J
JerzeySlowpra
Guest
i grinded the ridge down, and it fits how, it has about as much clearance that you do the only thing i dont like is i made a pin hole by accident at the top but it doestn seem like anythign would leak out of it because theres no way for oil to get to it, assuming that the inside of the roof is hallow... so i dunno what it would do under preasure
williamb82
907
4
Tampa, Fl.
any updates supragirl? i myself got my wastegate and the new valve guides so far. still waiting on the manifold. should be here tommarow. and my friend dave said he is almost done porting my head. next is to have the new guides and oversized valves installed and then have it flowtested.
william
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
oooh cool!!!... i gotta get a new one coz the 38mm i had doesn't fit my manifold... and the only ones in stock is 50mm LOL... so i have to get that one... but at least that fits hehe
gotta get the flanges made for the turbo (quite annoyed the turbo didn't come with flanges) and oil return and buy ss lines for the oil feed
get my ffi finished and bolted on
get my car in primer........ one day LOL
time is running away on me ;)
what valves are you putting in your head?
williamb82
907
4
Tampa, Fl.
the oversized ones that were being sold on ebay. the 4x4 toyota guys swear by that guys products, and from looking at them they seem to be top notch. got a set for the 6m im building too. oh, and the wastegate i have is 50mm. lol. though it doesnt have the vac hose barbs, or the plate that goes on top of the spring to adjust the pressure, so i had to make a plate. and ill go to napa later for the barbs.
williamb82
907
4
Tampa, Fl.
heres some of the shavings from the port work my friend dave's gotten done so far on my 7m head. still lots to go.
heres my new ss turbo manifold.
and here, you can see the ports to the tubes going to the waegate need to be ported alot more. for some reason they didnt open them up all the way. no biggie. i can fix it easily enough.
and here is the wastegate bolted to the manifold and me holding the turbo up to it. it needs a 1in spacer for the compressor housing to miss the #2 runner.
all pics courtisy of dave a. and no, im not gonna use that huge turbine housing. im gonna order a 0.68 a/r for it. just been busy buying other stuff at the moment.
suprra_girl
7M POWAH! ;)
www.supra.co.nz
yea i was curious how the wastegate thing was gonna work (lookin awesome by the way)
will it hit the ground? LOL
they look fairly long and the wastegate flange is like flush with the sump lol
if you get ur engine in before mine lemme know how it goes lol
:( wheres the top half of you :p
williamb82
907
4
Tampa, Fl.
it better not come close tot he ground or im gonna be pissed. i need to bolt the mani and wastegate onto a spare 7m and measure the distance from the block to the outlet to see how much room is between the outlet and the frame rail. hope its enough for the 2in bend. if not, gonna have to cut the flange off and turn it 90 deg. and the other half of me isnt in the pic. wasnt what i wanted a pic of. lol
william
suprra_girl
7M POWAH! ;)
www.supra.co.nz
so i got more painted on the car and some pics of it naked ;)
no that's not me naked... the car :p
Got the engine bay in primer today
Another pic also showing sanded down rear
Couldn't resist a pic of my drainpipe ;)
Primered front bumper
Definitely lost some weight :p, gutted while i repair
Another gutted pic
Really gotta fix that rust before i have no boot
Rear of car gutted, gonna get my rear 1/4 windows tinted while i'm at it
suprra_girl
7M POWAH! ;)
www.supra.co.nz
sooo... i finally have some more to show :D
finally got the engine bay painted woohooo
where the really shiny/whitish parts are on the curves is actually the gold pearl :D
full bay pic
another angle
another one
some bits ready in primer
my replacement roof
standard jdm rear
now will be usdm rear :D
still needs filing and squaring out properly but i'll get a finished pic soon
