Update Nov 2010:
It's been a while since I updated these build threads so, thought it was a bout time seeming as outside in the yUK is now a no go area for the next 6 months....
This car has actually been on the road since June 2010, in weekly use day or night, mainly dry weather but, not opposed to taking it out in the rain & it's even been salted thanks to a rather over zealous council whom will run out of salt when we actually need it....
April
While while waiting for 2jz water pump parts & pulleys to arrive I diverted attention to less important stuff, one of these items was daytime running lights as in my post above so, I shan't go into those again in this reply
A dedicated thread for these is located
HERE.
May
The 2jz water pump arrived, this is a direct fit onto the 1jz with the hydrofan system removed.
http://www.forum.mkiiisupra.net/showthread.php?p=324043#post324043
Pump installed & fluid refilled, no leaks this time!
Hydrofan system binned for twin electric fans from a Ford Mondeo.  These Siemens fans really shift some serious air & the cowling fits perfectly.  Again, a dedicated thread can be found
HERE on the retrofitting of these fans.
The fans fit into the 1jz with a small amount of modification to the cowling plastics to clear the boost pipes & huge Koyo rad.  On the 7M these just drop in.
Little ally brackets fabed up use the stock mounts on the rad.
Stock look once 2jz pulleys were fitted up, the serpentine belt stays stock too.
To aid cooling I made up a solid front part to the under tray out of ally sheet.  This replaces the front part of the plastic under tray diverting all ram air through the coolers & also strengthens the front lip - bonus.
A small mod was carried out to the stock 1jz fan ECU that allowed it to interface with the electric fans & run as if stock.  I also incorporated a dual speed system to simulate the constant movement of the hydrofan along with full pelt on demand cooling from the fan ECU & manual override switch.
In addition there is also a timed cool off period that runs the fans after engine shut off.
The slow fan speed dropper resistor is a stock fuel pump dropper while I used spare fuel pump relays I had to control the rest of the fan system, all bolt up to existing threaded holes in the chassis.
Early June
Car all back together complete for the first time in months!
Front end with DRLs fitted properly.
DRLs with sides.
Rear end with rear DRLs on in corners.  These dim at night as part of the tail lights & serve with the brake lights too.
Electronic with remote trunk release fitted - having to use a lever to open the trunk always was & always will be one of the dumbest ideas ever!
The switch lights blue when the system is active, pressing it operates the trunk solenoid.  The system is all interlocked with the central locking & alarm for remote operation also.
June 21st 2010
Off to Surrey Rolling Road to get the thing tuned by Ryan G.
We did hit a slight snag with regards turbo boost flat lining at XX point, almost as if a valve is controlling it perfectly - this is being dealt with on a different thread.
The MAP has just been set to work the car below this threshold at present &, when I can be bothered I'll look into the issue.   Driveability is not effected by this problem, just top end power.
One of the Syvecs never ending screens.
Once al the mapping was done for this session I was able to mount the Syvecs ECU properly.
---------- Post added at 12:48 PM ---------- Previous post was at 12:47 PM ----------
Update Nov 2010:
With the car back on the road & all the shakedown complete I enjoyed the car over the summer months as weather allowed, taking it out any excuse.  It's an absolute dream to drive & feels like a new car.
Handling is impressive, the powers great even if we are short by about 120 BHP at present Lol.
July & Sept 2010
Just tweaking really from here on.
Temporary control panels fabricated for the Syvecs & traction control systems, along with other new electronics installed during build.
Pass view - This is really hard to photograph as the digital cameras make blue light look like the sun!
Drivers side
The trunk build got a revisit.  I formed a dropped down section behind the rear seats to make use of wasted space, reduce the speaker baffle to improve resonance characteristics & split the build into 2 pieces which allows it to lift out without the need to remove the strut brace & forward targra holders.
I also lit the Audison amps to match the trunk lighting & installed some crafty hidden lights to the targra holders so they can be found nice and easy at night.  These come on with the trunk light.
This is just a bit of fun, I made this circuit up about 14 years ago & it's been a kind of standing joke / trade mark ever since - I give you KITT Lol.
Car in the sun - a rare thing here in the yUK - country of perpetual grey sky.
Engine porn.
Lit up engine porn.
Trick blue over spark galley when seen from side.
A few videos for amusement.
Push button transponder key less start demo.
[video=youtube;BwJwGgy65Kk]http://www.youtube.com/watch?v=BwJwGgy65Kk[/video]
Daytime running lights operation with auto sides.
[video=youtube;v85ml1zFWs0]http://www.youtube.com/watch?v=v85ml1zFWs0[/video]
LED rear conversion.
[video=youtube;0dTeU2luRuM]http://www.youtube.com/watch?v=0dTeU2luRuM[/video]
Obligatory scanner vid LOl. (for the kids you understand)
[video=youtube;xw4iN1MY6yA]http://www.youtube.com/watch?v=xw4iN1MY6yA[/video]
So, that's it for now, the car is on the road, in full use & has been for 6 months now.  There's still plenty to do restoration wise, the next big thing being the bodywork which will be undertaken after christmess.
I also have the boosting issue to investigate but, TBH, the thing drives so well without the addition power at present I just want to enjoy that for a bit instead of pulling things apart again - you never knw, it may even fix it's self .... yeah rite!
Shiny car ready to deploy.
