Supra makes wierd rattling noise after 3000 rpm on every gear HELP!
8
89MkiiiSupra
Guest
Hey guys, so check this out, i got a great deal on this supra for 4500. basically this guy rebuilt the motor and it has under 10,000 miles on it. he did alot of mods including
New Air Compressor Jun 08 $ 225.00 New A/C Drier Jun 08 $ 45.00
New Radiator Apr 08 $ 211.00
New Alternator Feb 08 $ 93.00
New Wheels Feb 08 $ 751.04
New Tires Feb 08 $ 725.00
Air Cleaner Hose Feb 08 $ 55.22
Lower Radiator Hose Feb 08 $ 31.00
HKS Metal Head Gasket Feb 08 $ 105.00
ARP Head Bolts Feb 08 $ 115.00
Head Gasket Set Feb 08 $ 223.05
Power steering Hoses Feb 08 $ 25.00
Thermostat Feb 08 $ 7.00
Rebuilt Cylinder Head Jan 07 $ 525.00
Fuel Injector Seals Jan 07 $ 35.04
Timing Belt Jan 07 $ 50.48
Timing Cover Seal Set Jan 07 $ 26.60
Valve Cover Gasket set Jan 07 $ 24.00
Heater Hoses Jan 07 $ 134.67
Spark Plugs Jan 07 $ 18.60
Total Wheel Alignment Jan 07 $ 60.00
Front Sway Bar Jan 07 $ 165.69
Front Sway Bar Link Jan 07 $ 60.78
Front Struts Jan 07 $ 78.27
Rear Struts Jan 07 $ 78.27
Front Brake Rotors Jan 07 $ 156.74
Brake Pads Jan 07 $ 20.18
Rear Brake Rotors and Brakes Jan 07 $ 151.88
Rear Brake Pads Jan 07 $ 17.97
Lower Ball Joints Jan 07 $ 118.56
Parts Total $4334.04
* Engine Rebuild @ Approx 167k $ 2000
Total After Engine Build ( minus Labor ) $ 6334.04
Approx 10K since motor rebuild and 1000 Miles on recent Head Work.
So i got this for a pretty good deal, there were reciepts and everything. When i got the car everything was fine, but than i let one of my friends test drive it, he made sharp ass u turn and my wheels spun out and we basically drifted sideways left to right and he was about to crash my fcking brand amazing ass supra into the pole but he got control again. than after maybe about 10 mins i started hearing a rattling noise everytime you past about 3000 rpm. So i brought the car back to my house and reved the engine and it sounds horrible, before 3000 its fine but after than its just a bunch of rattling. CAN anybody tell me what this is? Possible when he spun out my wheels he couldve snaped something or possible made something loose? I was going to take it to the shop but i dont want them telling me a bunch of bullshit so i wanted to see if anyone on here had the same problem as i. thanks
8
89MkiiiSupra
Guest
oil was just service 300 miles ago. all fluids are up to date checked and made sure everything was full and clean.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
jetjock;1106327 said:
Define "full"....
yeah really... you took off the fill plug on the trans and diff to double check? you pulled the dipstick and triple checked it?
i still say post up a video... i dont wanna jump and just say "omfg rod knock" cause it might not be...
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Simple stuff first; check all the external stuff bolted to/near the motor.
example: I had a horrible rattle that scared the shit out of me, I thought it was something in the motor that let loose. Much to my relief, it turned out to be a loose heat shield vibrating and making a terrible racket.
nosman4
133
Bend, Oregon
If it makes the noise while you are just sitting still and reving it, then listen to see if it is coming from the engine area or somewhere else on the car. Just like Rennat, I don't want to say it's Rod Knock, but your description does sound somewhat similar to it. Try to narrow down where the noise is coming from, top or bottom of engine or not the engine at all.
8
89MkiiiSupra
Guest
well i took it to the shop and they said it could be rod knocking.. so right now im like wtf...
Hence JJ's comment:
jetjock;1106308 said:
Maybe he unported the suction screen during that little fiasco. If so that would not be good...
Meaning the oil pump pick-up tube = loss of oil flow to the motor.
I'm thinking you need to be more careful about letting "friends" drive the car. You don't need friends like that.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
jdub;1106953 said:
Hence JJ's comment:
ahhhh i get it 'unported' = no longer submerged. yeah... but wouldnt he have to had like 4qts in there? cause if its full it shouldnt become open could it? i used to do a lot of 'spirited' driving around town, and even up the back roads in the mountains, and i've never had a problem with anything except traction. haha... but i also ran 6qts...
8
89MkiiiSupra
Guest
well i made sure all oil and fluids are there and everything seems to be fine. if it is a rod knock im going to be mad. i was at work all day so i didnt have a chance to really get some answers on my car. people is telling me that i should just get a new engine instead of trying to get the rod bearings fixed. what do you guys think
SideWinderGX
733
Syracuse, New York, United States
With the stock 5 quarts of oil in the car, under hard cornering and/or braking, ertain parts of the engine and oiling system are deprived of oil.
Running an extra quart or two (I run two over) will not harm anything on the motor (no oil seals), and won't rob any horsepower, as the crankshaft doesn't dip into the oil pan. It will give you more than enough oil to save your ass under hard braking and cornering, where the engine needs a good lube system the most.
Sorry to hear this happened =\
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
Well, first I'd make sure that it is a rod knock (supracentral has a thread somewhere on how to detect rod knock). If it is rod knock than you'll have to look at the rod journals and make a decision on the damage.
In short if your rod journals are damaged than new rod bearings aren't going to last very long, and you might as well bite the bullet and have the crank machined and do over size bearings to match. If you go the band-aid route and just do the rod bearings, your knock will return shortly.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
most of the time the bearings are softer than the crank, so you end up beating the bearing onto the crank, and it should be able to be cleaned up.
wasnt the easiest way to tell if you had rod knock was to pull the lead wire to each cylinder while its running and rev it?
