Strut to Turbo and Manifold Clearance with Hard Motor Mounts
p5150
ASE and FAA A&P Certified
Central Idaho
Im dropping in my GT42 and building a custom FFI and the clearance from the strut to the compressor housing or FFI can be/is pretty small. I need to do some mods .
How much clearance between the side of the turbo/FFI to the struts do you guys think I need?
Keep in mind that I have 88 hard mounts and not the later type.
How much movement/twist side to side have a few of you with gobs of torque seen on the dyno?
p5150
Central Idaho
Yeah, 2JZGE-T, but torque is torque and it will be using 7m mounts. So 7M or 2J advice/experience would be good here.
Tun_x
Built to do the NASTY!!
Utah
here ya go.. I have solid motormounts though
p5150
Central Idaho
Thanks for the pics bro, but I need to know how much the motor is rocking side to side on full throttle pulls - not necessarially how to set it up. My mounts are pretty solid - they are from an 88 so they shift just a bit.... not much.
I also have a slightly different setup than you and i dont want to modify the manifold If I dont have to, and i dont think I will with an extra flange as a spacer....
I would like to know how much movement..... X-man? you have a dyno and a big blower.... how much movement?
p5150
Central Idaho
IJ. - I never heard the motor mounts called a "torque limiter" - I just wanted to make sure we are talking about the same thing.
Would you say that your motor mount setup is the same as mine?
Early Mk3's have a torque limiting shocker bolted to the side of the motor then to the subframe!
I'm just using a new set of 86.5 Square mounts after tearing my 20 year old ones at 500+rwhp! (Torque limiter stopped them ripping right through)
p5150
Central Idaho
OK - I know what you are talking about... Ive seen those before. I think im using the same mounts as you are. We will see how they hold up when I really turn up the GT42.
p5150
Central Idaho
The limiter is like a little shock/strut right? I saw one but I think it was FUBAR. Im pretty sure I will have to buy a new one if I want to use it. I will check the price on my microfiche.
Right now, im really pressed for space. Do you think Ill be good with 15mm of space between compressor and strut tower?
15mm is about as close as I'd go using something as a limiter.
It "shouldn't" move anymore than that but you're going to be putting a lot of power/torque into it!
Pity SF is broken the Mk4 guys would be in a better position to answer this.
I've got a limiter and square mounts on my '89...came that way from the factory ;)
p5150
Central Idaho
Good vid! Looks like around 1 inch? And that was around 500 hp? I suppose there comes a point when the rubber wont compress anymore I wonder if 700 hp would move any more than 500hp.
