Starts Barely When Gas is Feathered
bigboostinmk3
15
ohio
I bought an 89 mk3 turbo a year ago. It is currently at my fathers shop about 100 miles away from me. We have both been tinkering on it the past year. He is a good mechanic but doesnt know this car that well. The car doesnt have exhaust on it because the people we bought it off thought the cat was plugged and cut it off.
We got the car not running so we started at the simple things first. Checked firing order it was messed up so I fixed that and the car actually started when you pump the gas while cranking and feathering it when it does finally start. It runs rough and backfires and sputters and then dies and it wont go higher then 3krpm. The security light comes on once in a while. I dont know if that has something to do with it or not?
Anyway we replaced the fuel pump and filter. Checked voltage to the pump which was good. I then bought a used 90 ecu which doesnt do anything to help the car it wont even start it. Then we replaced the fuel injectors, rail, and FP regulator same thing. What is weird is the car comes alive when u spray ether in the TB. Can I check the codes when the car if not running? How do I check if my AFM is good?? All I know is the spark is good and the fuel pressure is good.
I have been reading and reading on these forums and I came to think it may be a CPS problem or wiring problem just because of all the symptoms people are having. I am mechanically inclined but I dont know where to start. I hate to just start throwing parts on it or put it in a shop and pay for nothing and still have a car that doesnt run. Can someone lead me in the right direction. I have been doing my homework on this thing.:1zhelp:
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
Check the physical timing of the engine (actual piston position, cam position, timing belt tension). Make sure that the engine is physically "in time". Set the CPS to the correct position according to the links below. This should get you running enough to get the timing to exactly 10 degrees BTDC (you might need to get someone to help you by keeping the car alive as you are messing with the CPS).
General info:
http://www.cygnusx1.net/Supra/techtips.aspx
Repair manual:
http://www.cygnusx1.net/supra/library/TSRM/mk3/
Timing belt specific page:
http://www.cygnusx1.net/supra/library/TSRM/mk3/manual.aspx?S=EM&P=22
Cam position sensor specific page:
http://www.cygnusx1.net/supra/library/TSRM/mk3/manual.aspx?Section=IG&P=21
bigboostinmk3
15
ohio
one more question. If I get a lexus ls 400 AFM do I have to get 550cc injectors, or can I run it with the stock injectors and stock turbo? Will it cause a power lose? When I set the timing does the diag box have to be jumped?
I swear it's like pulling teeth...
Any computer controlled car is considered "smart" in that it usually knows what's wrong in some way or another. One only has to ask it...
bigboostinmk3
15
ohio
today i checked the car out and the only code that came up was a 51. which is the ac switch and tps. I dont even have the ac hooked up. anyway I did an ohm test on the cps and the resistance was 238 when cygnus says it should be 140-180 ohms. Could this be my problem. I also checked the timing and the physical timing was right on the mark TDC. The cps marks were lined up fine also. Where do I go from here?
bigboostinmk3
15
ohio
Could the tps stick open and cause it to act this way. or is my cps bad with the resistance that high. Also I forgot to mention this car has a factory alarm system and when u crank it the security light stays on. Now the car wont start at all. Does the security system cut out spark because i know we have good spark to all the cylinders? I am going to test the tps sensor next. In the mean time I probably will try to find another cps for a reasonable price? Any suggestions
