starter is dead aka no clicky
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well this blows and i really tired right now
any way
i was extending my alt wire and grounded out the constant 12 volt on my alt wire the white and red dotted one
well now my hole startign system is dead no click nothing
according to the wiring digrams there some fuble links or fuse i cheak all teh one si know fo but nothgn all work fine
help me out i kidna pissed off and tired and pissed off
fucken car
8,900
You have to have multiple blown fuses. The alternator is parallel to the powersource off the battery. Usually, the fusable link goes if that happens. But remember, the link does a quick burn, not a pop like a fuse. It is bolted in and you have to take the box out to get the screws.
8,900
What year? I am going to look at my 91. That wire is still parallel, and goes through two fusable links as you mentioned.
edit: I didn't read your original post close enough. You touched wires together in the harness? I thought you meant you touched one to ground.
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=042
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yup some thing died pas thus 2 fuse's
only thing after that is tumbler switch
the relay in the passenger kick is fine too
i am baffled and i can't see tubler gettign killed for the 30 then 40
8,900
Did you check open circuit voltage on that wire? That will tell you if the circuit protection is tripped if you don't see it.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
i ahve yet to test it all because it so dam hot
in about 1 hour i going out to see fi cna get the pos to run and test more in depth
NashMan
Aug 5, 2005
4,940
17
Victoria BC
ahh there more to this my sun roof does not work no more nor does my e brake light nor does my power mirrors and cig lighter and power windows
i think i might know what it is now
NashMan
Aug 5, 2005
4,940
17
Victoria BC
back to the wireing diagrams
from what i see here is must be the igtion switch
but i have never scene one of these go ever
NashMan
Aug 5, 2005
4,940
17
Victoria BC
does any one know were i can find pin out for teh ig switch for 91 and 92
because there different in 91 and 92
NashMan
Aug 5, 2005
4,940
17
Victoria BC
edit found the pin it's the same a second gen mr2 because they share the same turbo timer harness
and the ig switch works fine....... fuck now what ???????
this all so makes 90 wireing digram use less
i look up the 1jz but shits all in jap
GrimJack;1605125 said:
All I've seen is the '90... (http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=BE&P=15) although, why would they change it? Something to do with the airbag system?
i don't know but they did and not sure why
