In theory, if your TPS is set properly, a vented BOV should do absolutely nothing in regards to stalling. In theory, this is what would happen...
Boosting, half throttle or so, TPS IDL contacts are open. Engine speed has to be above 2000 RPM IIRC
Let off throttle, TPS IDL contacts close, since engine speed is over 2000 RPM, ECU cuts fuel.
Engine drops below 2000 RPM, ECU resumes fueling. All of the air should be vented from the BOV and it should be closed by now.
The problem occurs if your blow off valve opens around or under 2000 rpm. THEN you run into a rich scenario, as the ECU will NOT cut fuel.
Ever notice how if you engine brake above 2000 rpm it doesn't afterfire? Thats because the ECU cut fuel..
