Ok...so the idle problem was corrected with plugs/wires correct?
There is a ground from the coil pack plate already...it's a field ground and should not have anything to do with what you're getting now. If you want to replace it, just run a wire to an available bolt on the block or to where the battery ground bolts to the body.
Do you have any codes?
