Spring meet Vancouver!!!
Turbo Drifter
534
Surrey, BC Canada
As posted on Supra Forums:
Event: Revscene.net Annual Spring meet 2009
Date: March 22nd, 2009 (Sunday)
Time: 12 noon
03.22.09 (March 22nd 2009) Mark the day on your calendar. Revscene.net Annual Spring Meet!!! Time to put back on the rims, wash off that dirt and salt. And show off what you got during Christmas for the car!
More info to come!!! Spread the word to all the car clubs so that you can come with your car crew!!! Roll in together to park together. Come represent for the community!]
Like with every spring meet, this is a grass roots type meet. No thrills, no gimmicks. Meant for family fun, community awareness, and to dust off the dirt, bring out your ride. As always, idiocy will not be tolerated. Be on your best behavior, you are representing your crews and the automotive community.
From the sounds of it we are meeting at BIC Performance and heading in from there.
Jeremy
JustinGotA1j
532
Chilliwack
I'm in for sure. Any idea what time everyone is meeting at Randys? Looks like the rest of my week will be spent getting the car ready haha!
Turbo Drifter
534
Surrey, BC Canada
Working on that, waiting for Randy to set up a meet time at his shop. There is talk of Breakfast but I want to be on the road to Spanish Banks by 11am so it will be and early morning for some if we do Breakfast first.
Jeremy
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
im down depending on my car! have to find a coolent leak im losing lots of coolent but no milk shake any where to be found.
Turbo Drifter
534
Surrey, BC Canada
Is it boiling over and out the overflow? put a condom on the outlet of the overflow and see if it fills with coolant. Also look at the hose at the back of the cylender head up top and the one behind the water pump. You may need to move the hoses a bit to see a crack and leak.
Jeremy
Dec 3, 2003
6,653
Canada
Overheating? You have a 7M? 100% head gasket.
J/K
Fix it, and come out. I'll will be working on my car Sat but riding with Dave on Sunday. Can't wait to see all the new mods. I know Jeremy's car will look better, he has new interior. :sarcasm: I know what's up. :)
Duane
becauseican
Vancouver
www.bicperformance.com
The weather forcast looks good. Anyways if you guys are up for meeting at 9:30 we can go to IHOP for breakfast that gives us 1.5 hous to eat and BS and leave at or just before 11 am. If the wait is too long we can just run to McD's for some McGriddles. So I will be here at 9:30, here is a link to the shop:
http://maps.google.com/maps?f=q&hl=e...wloc=addr&om=1
Randy
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
Jeremy
no bubbling out of the overflow tank, but im going to be looking at all the hoses today cause i saw i bit of water/coolent looking running down the passenger side of the block, like behind the water pump. im crossing my fingers for no BHG lol:cry:,
Dec 3, 2003
6,653
Canada
I have a sniffer here if you want to borrow it, it will tell you right away if you have exhaust gas in the coolant.
Breakfast, 9:30? lol Can we meet earlier? Why so late?
Duane
TobyCat
470
Vancouver BC
I had the same problem with coolant down the passenger side of the block. Check the rubber cap on the back/passenger side. It's where the RHD heater core hooks up...Mine was all gnarled and cracked from old age :)
As for the meet, not sure if I'll be able to come out. I'll wait a bit for the next Vancouver mini meet to take the ferry over for the day ($100 bucks booo).
-Chris
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
-Chris
well i was looking and its coming from like the rear of the water pump and isnt the heater hose in the rear on the head? and end of the block.
Turbo Drifter
534
Surrey, BC Canada
How is the 90deg rubber hose behind the Waterpump? Maybe one of the turbo water lines I think they hook up back there too.
Jeremy
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
Jeremy
well i will be taking it all apart tonight, and re-torquing the head and also look at all my coolent lines after work ill keep you updated.:1zhelp:
Dec 3, 2003
6,653
Canada
I've never re torqued the head, if done properly the first time, no need to go back. Check other things and again, if you want piece of mind, I have a sniffer here.
Duane
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
Duane
yeah ive never re-re torqued a head also, i did it after 500-1000km after the job and it was fine. but yeah i was thinking of just looking over the hoses so yeah. i actually might come down if i cant see anything.
Turbo Drifter
534
Surrey, BC Canada
I would not worry about re torquing, I checked mine this winter for peaice of mind and it had not changed at all since it was put together. If you have already checked it once do not bother doing it again. If the head gasket is the problem a 2nd re torque will not fix it. I would borrow Duanes tester and know 100% they do not lie.
Good Luck man!
Jeremy
Dec 3, 2003
6,653
Canada
2 things required for having a 7M
Extra gasket
Extra coolant
Tester to see if coolant is present in engine
Just kidding, yes, I even have a sense of humor.
Duane
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
To isolate the leak, you can also buy an ounce of leak test dye from Lordco that you put into your coolant, that will glow under UV light so it's easy to find. But do Duane's HG test first, or I have one as well you can borrow.
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
When I had mystery coolant showing up, it was one of the turbo collant lines, right on the bottem, so it was extra fun to find.
