spring installation?
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
Ive never uninstalled and reinstalled a set of springs... is there any How-to posts saying how???
i just want to be safe so the springs dont shoot out and kill me..
yes i have the spring compressors too.
jugodegolf
Phoenix,AZ, United States
I had Noah help me, we just did mine. If you have a friend to help it is pretty easy. Note when you take out the pin that holds the bottom in there is a bushing that might need to be tapped back out to make room for new strut to slide in easily. GL
ValgeKotkas
2,224
Over the pond
Front
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FA&P=17
Rear
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=RA&P=57
For the front, pay attention as in what position you tighten the upper susp. arm. (lower arm must be in it's natural position(saves upper arm's bushings as I understand)). That's step #5 on TSRM.
Like once IJ said, put something under the lower arm and lower the car to the natural position, torque down the upper arm, raise car, put wheel back :) Atleast something like this.
selfinfliction
434
ky
do you have the compressors with the safety pins on them? if not i would suggest renting/buying a set from autozone. idk on the supra specifically, but a spring/strut job is usually extremely easy, it just takes time
<edit> i just looked at the manual, that spring compressor with the long forks they are using in the illustrations... does anyoen know where to get one like that? that would make life much easier, than using the two compressors like usual
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
i dont know how they get that damn upper arm bolt in there on the front, after slideing it otward, and behind the fender cover, i still hit a frame member and the damn thing wouldnt come out far enough to release the upper arm, took a lot of effort to get it out
Nomad707
Im From The Bay
Mar 14, 2007
1,039
it took me 2 hrs to get nowhere today.. i got my a arm bolt out and swung the a arm out of the way... i got the shock and the spring in, but i cant get them into the seats... this is so annoying...
ill work on it more tomorow.. pics to follow. (on my build page)
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
I know you're having trouble getting the bottom in. What I did was put in the top and put on the three bolts to hold it there, but not nearly tight. I just threaded them on enough just so that they were on so the top wouldn't slip back out.
The bottom didn't exactly glide it, but either line it up with the bracket on the bottom from behind, in front, or the top and line up a 2X4 or something that wont damage it and give it a few taps and ur good.
Bolt usually lines back up no problem and before you know it, it's over and you're gonna be taking pics of ur ride dropped. Good luck, let us know how it went, and what you did.
- Shankar
Nomad707
Im From The Bay
Mar 14, 2007
1,039
my dad is coming to help me.. he knows more and can do it faster.. he is going to do the fronts while i do the backs... i will have pics as soon as im done.. i have a feeling its gunna have a nice ride height and nice ride quality. it already has the GR2's (but stock springs) so hopefully this will drop the car a bit more.
Pics to follow progress!
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I had a pain getting the bottom of the rears in. I ended up grinding a hair off the bottom of the strut where the bolt goes through to make it fit. I had to do it with the kyb-gr2's and my megan coilovers. I know there is some kind of spacer on the suspension at the bottom, but I couldn't get it out. So, I said screw it. It appears to be working though.
