Speedometer works, but odometer doesn't
s turbo 87
Accepting Donations
Louisville, KY
I recently got my 91 turbo automatic back on the road after installing a new engine and transmission. The speedometer works just fine but the odometer doesn't. I only drove the car a few miles before I pulled the old motor/trans out over a year ago because it had a BHG and a rod knock, but I noticed then that the odometer wasn't working then either. Any ideas of what may cause this or how it could be fixed? My guess is that I just need to replace the cluster.......ideas?
Tried searching but I couldn't find anything.
Thanks.
mkiiichip
1,434
WI
The issue is definitely in the cluster, maybe take it apart and see if you can find the issue, or replace it.
