speedometer gear difference?
JesseH
1,153
Englewood, Ohio, United States
Ok, I know there is a different one for each gearing, but what about between the auto and manual? or post and pre 89? Ive got like 3 or 4 in various G/R's but not 100% sure what they came out of, Iv'e got a 3.9 thats got a smaller gear and about 1/2 wide, then another thats a bigger diameter gear but about half the width.
after reading this:
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=3505&P=1
and this:
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=3304&P=1
the auto and manual would be the same correct?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I can only help by offering that the W58's speedo drive gear is larger in diameter than the R154's.
JesseH
1,153
ok, thanks any info is good before I try this...I dont want to tear up a perfectly good speedo gear
OT: where have you been hiding? lol havent seen you on in awhile.
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
From looking into the parts before. (Swapped a turbo 3.909:1 LSD diffy into my '89NA with 4.300:1 LSD from factory)
R154 gears will not fit into a W58, however, the A340 gears are interchangeable. if I'd had an auto, I could have got gears to fit. The A340 gears don't fit in either the R154 or W58, from the information that I got.
Coles Notes:
W58 gears for W58 only.
R154 gears for R154 only
A340 gears okay between NA, pre '89 and post '89. swappable.
