special evolution edition of the 7M-GTE: WTF?
Dirgle
Conjurer of Boost
Pauma Valley, CA
I was digging through this artical:
http://www.explore-cars.com/motor_vehicles/T/Toyota_M_engine.html
and read this:
7M-GTE
The turbocharged 7M-GTE was Toyota's top performance engine from 1987 through 1992. Output was near 230 hp (172 kW) at 5600 RPM and 240 ft.lbf (325 Nm) at 4000 RPM for most 5 psi/0.35 bar versions.
A special evolution version with a different turbocharger pushed output to 265 hp (198 kW) at 5600 RPM and 264 ft.lbf (357 Nm) at 4400 RPM.
WTF is this? Is this the Turbo A? I've never heard it called evolution version
Squid699
Manic Mechanic
Chesapeake, VA
As far as I know the Turbo A didn't have a diff turbo, diff cams, diff air metering and other things........maybe they meant 1jz? :confused:
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
the turbo A had a differnt turbo, a differnt verson of the ct26 called the ct26a, it had different cams and map sensing instead of a restrictive mass airflow sensor like so many of us are plagued with. i believe it also had a bigger throttlebody as well. im sure someone will add to this list if i didn't get it all. i would assume they mean the turbo A. it was probably their way of saying it was a special model. thats the best i can do. the tech guru's will probalby have more/better/clearer info for you.
Dirgle
Conjurer of Boost
Pauma Valley, CA
I had a pretty good idea of what the diffrences in the turbo A were. What I was wondering was if the evolution version was another name for the Turbo A, or if it was something diffrent.
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
Sounds like the Turbo A to me.
Squid699
Manic Mechanic
Chesapeake, VA
Blue87T(Dan) said:
I don't think the Turbo A used a Karmann type meter.
It didn't, I just worded that poorly.
Stanza - I was wrong apparently - they did have different turbos, but I don't think that the differing factors was how it was marked. You have a CT26A too.....go look at your compressor housing.
Squid699
Manic Mechanic
Chesapeake, VA
MR2 CT26:
Supra CT26 (A):Notice the 'A' Marked on the opposite side of the compressor housing. All Supra CT's have that.......
shaeff
Kurt is FTMFW x2!!!!
11
Around
i was going to link to mkiiitech... but, MA70Supra88 beat me to it!
-shaeff
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
ya, i just what i remembered from the old threads on the old board was it was designated ct26a. i beleive it had bigger compressor wheel and ehaust housing, correct me if im wrong. :eek:
Dirgle
Conjurer of Boost
Pauma Valley, CA
Cool. Now when some mitsubishi guy talks to me about how bad ass the evolution is, I can say "Yep the supra evo sure is bad ass." :D
