son of a bitch to run or not to run ?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
SON OF A BITCH
well turns out my turbine wheel has sean some crap it not to bad but still fuck .............
gonna call PTE tomorrow
big qestion is should i just say fuck it and run it or fix it :cry:
pic's
toyotanos
What will we break today?
2,842
Coon Rapids, MN
Fix it for sure. Easy mode would be a new shaft/turbine wheel, I'd throw the bigger hotside (.80+) in for keeping the EGT's down- looks like it got really hot (might be the angles too)
Edit: even though the midrange will suffer, your top end will be un-corked :D
NashMan
Aug 5, 2005
4,940
17
Victoria BC
To fix this proper is to go over the hole egay manfold and make sure there is no extra slag to fuck shit up if i fix it but i really don't hav the time for it right now
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well i know i need to run a bigger hot side to kill off the heat so
the hot sid eo have right now is TH6865A
CT26smoker
223
Houston
What happened?
Crap weld debris falling off the inside of your chinese manifold?
Never mind, skipped over the thread too quick.
I see that it was the 'e gay' manifold.
Would never use one personally, too many horror stories like yours.
What did the turbo cost you ?
Cz.
CAR > FAMILY
Seattle, WA
If the wheel has been damaged then it will be unbalanced. That's going to cause problems in the long run so you're better off fixing it now before all the other parts get messed up.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
that what I figure
maybe it was because i went over the hole exhaust manifold and well there boogers but that shit wonte come off
i might even get it warrentyed
