some pics of my progress so far, quest for 10s
toyman1987
62
Omaha
once again another late start for me, thought I would share some pics of my progress so far. I have removed 200lbs including the weight of the roll bar, getting the AEM sensors wired in, still have to put Interior back together, get running and then Tuned. With the weight reduction and some more HP I hope to get into the high 10sec range. I have only used the NOS for turbo spool, but if I dont get the 10, I'll just spray the sucker all the way
Last year best time was 11.81 @ 117 Car was capable of a 11.5-11.6 but just couldn't get a complete perfect run in.
S&W 8pt Chrome Moly Roll Bar Installed by Sublime Speed Technology
toyman1987
62
Omaha
Justin727 said:
Looks hot dude. I'm taking u ran the 11's without standalone
stock ECU, with the MAFT, GM mass air sensor. could never get the tune right:3d_frown: either way too rich or would lean out at upper RPMs
The outside of the car looks like a magazine shot from the early 90's.
you can never see it in the pics, but it was painted with a blue tinted pearl.
B
Boostaddctn
Guest
Looks nice, got any more pics of the engine bay? and is that seat any comfortable?? :) aight peace :chicken:
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Yeah dude, MOD list! lol...
I had the same problem with the VPC set up I had... I'd either be really rich or really lean... We couldnt get that medium when trying to go over 23 pounds of boost... That's one reason Im going with an AEM too...
Thats awesome! Looks good... Can you gimme an idea of what you did with your head?
toyman1987
62
Omaha
Seat isn't as bad as I thought it would be, prob gonna add some foam to the back, but he butt part has about 3" of padding
this is last year, still have some stuff apart. will take new ones when it is complete.
Nice work on the cage is there any reason it didn't continue down to the rear rails to tie them in?
since the rear suspension is all under the strut towers, I guess I didn't see the need. If it was a leaf spring car, it would have been. can always do it later if the need arises.
SA-weet. is that the hpf turbo kit?? what size? are you gonna leave the interior stripped? good luck.
The interior is going back in.
that turbo is huge, which one is it?
Engine:
Machine work, Block bored, decked, Align Honed Mains, Rods reconditioned, J&E Forged Pistons,
Complete Rotating assembly Balanced, New OEM Oil Pump, New OEM water Pump,
ARP Rod Bolts, ARP Head Studs, HKS 1.2 Metal Head Gasket,
Head resurfaced, 3 angle Valve Job, TEP valve Springs, OEM timing Belt
All Coolant hoses And Vacuum Hoses New when Engine was Installed.
New OEM T.P.S., New OEM O2 sensor.
Turbo And Fuel Modifications:
Full Sound Performance Turbo Kit:
SP63 / .68 A/R polished and coated Turbo, Long tube 321 stainless Turbo Manifold,
3” downpipe, 3” midpipe, HKS GT Wastegate, SS Oil Line,
Fuel System:
Dual In-tank Walbro Fuel pumps, 8an Aluminum Fuel Line,
RC Engineering 750cc Injectors, TRD Fuel Press. Regulator,
All AN fittings, Braided Line,
Transmission:
Performance Rebuild, Raysbestos Blue Plate Clutches, Kolene Steels, new Sprags,
Washers and Thrust Bearings, Feed holes drilled,
Precision Industries 3500 Stall Converter, 3.73 LSD Rear Differential
Aluminum Driveshaft
Intrax Lowering springs
KYB Struts
Yokahama AVS Tires
MT ET Street Radials (255/50/16)
Brembo Front cross drilled Rotors
Akebono Ceramic Pads
Was just thinking it would increase torsional ridgidity quite a bit but didn't know if you had a specific reason to do it the way it's done!
Very nice cage :)!
(something I've been thinking of doing here)
toyman1987
62
Omaha
IJ, I checked out your buildup pics, nice work:icon_bigg
Who "hard welded" your cams? and what specs did you use? been seriously considering doing that.
Thanks :)!
I had one of the local Cam shops here in Australia do them.
I went a little conservative as I wasn't sure how drivable it was going to be with the low compression and didn't want to kill off too much low end!
.351"/9mm lift 280 degrees duration 226@50thou
