***SM Member Horsepower List***
92nsx
2,957
Clearwater, MN
288 HP & 308 TQ
The mod list for the low #'s
Eagel h beams, probe pistons, MHG, 1mm larger valves, BC 272 cams, port and polish, 3" hks exhaust, 3" dp, no cats, FFIM, FMIC. Im sure I forgetting a few thngs. But this is the base run, OEM fuel, OEM electronics, OEM ct26 set to around 11-12 lbs.
isnms
United States of America
Oklahoma
i80.photobucket.com
Slow66;1298859 said:
List updated.
I think its 100% up to date but if I messed somone up, let me know.
4-18-2009, that's pretty dang recent for people with other things to do.
What's with bouncing through all the treads harping on updates??
topgear
The Thrillseeker.
Jun 4, 2007
80
Tallinn
mods:
3 angle valvejob
Ported head
ARP Pro Series Head Bolts
Clevite 77 Main & Rod Bearings
Wiseco Pistons & Rings - 7MGTE - 84mm Bore, .040 Oversize, 9.0 Comp Ratio
Eagle H Beams 4340 Forged Chromoly Steel Connecting Rods
Fidanza Built To Fly Flywheel
RPS Bronze Stage 5 Clutch Kit (Sprung Disk)
HKS (Stopper), 2.0mm MHG
Toga High Volume Oil Pump
Custom Stainless Exhaust Manifold
MP T70
40mm UnKnown Wastegate
BIC intercooler
2.5" stainless intake piping
Spearco Intake
Custom 3` Exhaust
PIT Blow off Valve and Flange
Walbro 255lph Fuel Pump
WR Adjustable Fuel Pressure Regulator
RC Engineering 1000cc Injectors
Polurethane engine mounts
AEM
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
By doksurf33
-93 2jzge w/130k, TT headgasket
-Stock 7M ECU/Harness, Lex AFM
-SSAC T4 Manifold
-Masterpower T70
-HKS knockoff 50mm wastegate with 15psi spring
-Aeromotive FPR Kit, 2L surge tank, Bosch 044 external pump
-880cc injectors, E85 as fuel
-Chinese 2j downpipe to 935 3" DIY exhaust with cat and Megan GT muffler
-CX Racing 7M intercooler/fitted hardpipes
-Greddy Type S knockoff BOV
-Chinese special 4" intake pipe
-Apexi SAFC
-TurboXS dual stage boost controller
I dyno'd mine tonight. I don't have a graph because he was out of paper.
614 rwhp
561 rwtq
This was @ 25.6 psi of boost. It started going a bit lean @ the end of the run @ 7000rpm. It made it up to 12.1 and he cut it off. I made 575 @ around 24psi and that is what I'm running on a daily basis with my meth injection.
pt67
3" downpipe to 4" exhaust
SARD 624cc injectors
BC 272 small core cams
upgraded springs and retainers
CP pistons
Eagle rods
ARP hardware everywhere
Driftmotion intercooler and piping
Drewgo manifold
Tial 44mm wastegate
Tial bov
Snow's performance meth kit
Stinger EMS
Apexi AVC-R (I don't know how to make it do half of what it should do)
1.5jz
Stock intake
HKS DLI
Stock coil packs
plugs gapped to .020
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
This was my first ever dyno run. The car was un-tuned. I have since installed more goodies; but, here's what it had at the time of the dyno run.
Greddy 20G @ 13psi
Stock Fuel System except for Aeromotive AFPR
Sparco Intercooler
IC Hard Pipes
Fidanza Flywheel
HKS Super Dragger
Defcon Downpipe (I think)
Test Pipe
leecheater
Got a bad habit
Mar 27, 2006
458
St. Cloud, MN
My list of mods are on my signature. I want to be very clear there was more h/p to be had but we stopped at 22lbs. instead of 28 as planned. We were at 550 h/p and 515 lbs of torque. Several other gt35/2jz guys have made over 600 rwhp with this set up.
I am still working out the kinks and we will be back again to tuner before winter. I am just happy that this 2 year project is starting to act like we are getting there. Dan
gixxer750
2jzget comingsoon!
Mississippi
2jzGE
272 cams/aem/GTE cam crank sensor setup, sethron71 intake manifold, t70, 720cc injectors, self tuned, ported head, vvti coils
564 on 93 octane pump fuel.
yota8791
242
virginia
Slow66;1380259 said:
Need a list of mods to put you on there....
-je forged pistons (8.2.1 compression)
-stock rods
-bored .20 over
-block has had .10 milled off the top
-crank has been turned 10, polished and balenced
-head has been decked to match
-full valve job
-fully ported and polished head
-ported intake manifold
-ported turbo,
-new oem replacement cams,
-greddy 20g turbo with new internals(19psi)
-hks intake pipe
-ets 32x12x3.5 fmic w/ greddy hard pipes
-Tial 50mm bov
-Sard FPR with steel braided fuel line
-550cc rc injectors
-Walbro 255 fuel pump
-ACT stage 3 6-puck sprung clutch
-3in elbow, 3in piping
-HKS super dragger exhast
-aem ugo wideband
-ngk plugs and wires
-hks electronic boost controller
-hks turbo timer
-apexi neo afc
-rush anti-lag system
-HKS steel beaded 2mm hg
thanks to CWF Dyno and X-Man for the dyno time and tuning
becauseican
Vancouver
www.bicperformance.com
I guess I will finally get my self on the list. 449whp and 410 TQ, at 25 psi with 50/50 water meth injection. Dynojet. Best 1/4 mile 12.38 @116mph
Here is a basic rundown of the car:
-1jzgte swap
-USDM 2jz custom machined cams
-MK4 Denso fuel pump
-BIC top feed rail with 750cc injectors
-DBB SP61 turbo, .58 a/r turbine
-BIC custom 3.5" DP and Thunder catback exhaust system
-Haltech PS2000 EMS
-AEM water/ Meth kit
-Garrett/ Spearco custom 24x12x3.5" intercooler
-BIC custom 2.5" intercooler piping
10secdream
Got Boost?
Sep 11, 2007
767
Edmonton, Alberta, Canada
I guess I should get myself added on this list as well. 482whp 406TQ at 22 psi uses a 50/50 mix of water and methanol. Dynojet
Modifications:
1JZGTE
Jun 272 Exhaust, 264 Intake Cam
Bosch 044 inline Fuel Pump, Stock intank pump rewired
MK4 550cc Injectors
Apexi IHI C7 Turbo
3 inch downpipe, BIC 3.5" Catback
Devils Own Methanol Injection kit with M14 nozzle
Stinger Standalone EMS
ARC 18x12x4 intercooler with 2.5" piping
