***SM member 1/4 mi. times list***
toyotanos
What will we break today?
2,844
Coon Rapids, MN
Finally got to hit up a drag strip and made some pretty good passes! Going to need to fix the vibration up top to feel safe going faster but WHOO!
Best time of the day was an 11.833 @ 118.3 MPH :D
Built 7M, 67mm turbo @ 17lbs, BC 272's, AEM, E-85, R154, 26x10.5x15 ET Street wrinkle walls
Weight- 3530lbs
I am car # 1552
toyotanos
2,844
Coon Rapids, MN
Andy- still no idea.
Devin- Yes, an R154, but after that pass 2nd gear wasn't the same :( Couldn't/didn't want to get above 120 mph due to a really bad vibration that started up around 100, whole car was bouncing and jumping in shutdown :yikes:
Devin LeBlanc
1,830
Las Vegas NV.
Thats great, Hope to see you get deeper into the 11's looks like a good setup that is capable. What are you running the MT's at 15-16 PSI? Thats what I found gave me the best 60ft but every car is different. What do you think is causing the vibration? Drive shaft?
toyotanos
2,844
Coon Rapids, MN
13psi cold, around 14.5 after a couple passes. Didn't mess with the pressures too much b/c I was focusing on getting used the the bias ply sway. see my build thread for the vibration discussion ;)
Edit: Thanks Dan! We'll get your car up and kickin those drag Civics around soon enough!
suprarich
Guest
Nov 9, 2005
2,187
ohio
Mibrums time in the "other" class is an old time. Should be 6.95 @ 193 now. Their other car is a 7mgte powered mkIII car that ran well into the 8's, I would have to dig a little for that time, but it should have the #1 spot.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Need timeslips... or video... or something! I didn't even post my *own* time until I had a timeslip to scan and post. Otherwise Slow66 might resurrect himself and descend on this thread with the wrath of a man who's rules have been ignored. ;)
8,900
[video=youtube;keHP7k31s5I]http://www.youtube.com/watch?v=keHP7k31s5I[/video]
mk3_7m
536
melbourne
suprarich;1728860 said:
Thanks for that Nick!
Mibrum Racing's mk3 - GT45 last I knew, fully forged motor, GM PG trans, Mini tub
link to a 6.98@193 for the rail car
http://www.youtube.com/watch?v=FJ-bNAl6CCg&feature=related
Mibrum Racing 7mgte dragster - Mods are too long to list but is a GT4788 turbo, tec3r, SIP pistons, SIP crank, 5 speed gerico, water to air charge cooler, ect, ect,
Pwoa didn't know untill now he pulled of the 6 second mark. Better update the first list den ^.^ 7m ftw. On the other video i noticed the driver seemed to have a late reaction time.
gsxr141
1,158
10
rochester
well, i finally made it to the track with my $600 supra. lol
not sure how this stacks up, but i went 14.23 @ 99
my mods are..... k&n filter, shimmed wastegate, bic ddp, and full 3inch exhaust.
i was hitting 10-11 pounds of boost, and shifting around 5k.
also, i ran with the 17" cobra wheels and BIG tires. i figure that alone slowed me down, the funny thing is, i was spinning the hell out of them all through first gear.
