Size die to Thread Shifter?
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
Ive looked everywhere, but i cant find the answer. What size die is needed to perfectly thread the shifter? I want my stock shift knob back on i hate the set screw bullshit they suck. Please, someone help me on this.
supra90turbo
shaeff is FTMFW!
MA, 01440
Do you still have the old upper half?
You can cut the threaded portion off of it, plus about 1" of non-threaded length. Clamp the non-threaded part in a vice, and match a drill bit perfectly to the lower half that is in the car and drill through the piece that's in the vice. JBweld and let set overnight, or tack it in a couple places and you're good to go.
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
i'm with you 100% on this one man i've been looking everywhere for a stock shift knob i got some aftermarket hunk of junk on there now
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
I posted about it in the SOGI thread, but I just bought a 12mm bolt at Home Depot, and cut it.
Then cut the skinny part of the shifter off and welded the cut bolt to it. :)
Pretty fun and easy.
xarewhyayen
Oct 3, 2005
959
Philly
cjsupra90 said:
the stock shifter and shift know are 12mm X 1.25
Awesome. thats just the answer that i was looking for! thanks alot +1.
brent. thing is i dont have a welder and i dont know that i trust jbweld. never tried it... any opinions on jb weld?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
jbweld is a bitch to get off if it sets up correctly. we used it airsmithing to get stripped allen screws out. just jbwelded an allen wrench in the screw and broke the screw loose in the mornin, then just cut the wrench off above the screw.
but yeah, jbweld works great if it cures right. id still break out the taps and dies though.
MK3Brent
Very expensive....
Aug 1, 2005
2,878
If you can get another shifter... just send me what you want welded, just cover the shipping.
Clip
Oct 16, 2005
2,738
9
Virginia
sorry to distract the thread, but is the quality of a weld using an oxy-acetylene torch far below an arc welder? there's a small setup here and i was wondering if itd be wise to even get near any of my projects with it.
