Silver spark plugs?
Tanya
1,851
Naples, FL
Hi guys. I am trying to get some info on whether silver spark plugs are a waste of money or not. I am considering buying an MSD ignition box/adapter/coil and would like to be able to get the best spark out of my near-30 year old ignition system as possible. I had been under the impression silver was the best electrical conductor, but I guess that doesn't matter for spark plugs?
http://www.celicasupra.com/forums/showthread.php?63056-Silver-Spark-Plugs
Can anyone provide some insight or experience with these before I blow $60 on plugs and $277 on Nology wires :aigo:
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
nology wires do work as they claim but will you notice a diff most likely not but they do look pretty neat
only time hot systems are needed is high comp motor's or boosted or poor ign system to begin with
Tanya
1,851
Naples, FL
Well my engine is running around 230psi in every cylinder, so I had considered it a high compression motor which I figured may need a better ignition/plugs/wires than the standard crap I'm running.
For the life of me, I cannot get a compelling argument out of anyone why I should or shouldn't.... more than 2/3 replies would be nice. I kn ow there's some smart, experience people on here.
Plugs by themselves won't increase performance/ give a bigger spark...
Usually when you increase the "Zap" going in, plugs will wear out very quickly so a more durable material is needed, hence platinum and irridium plugs.
I don't know anything about "silver plugs" but I'd listen to JetJock if he say's they're snake oil I wouldn't touch them.
destrux
1,183
10
PA
I wouldn't spend that much on Nology wires. For most cars a set of NGK plug wires will work excellent... but if you really want to spend a fortune on plug wires I would recommend Magnecor Competition KV85 plug wires.... I always had good results with these on turbo engines. They have the best insulation of any plug wire I've ever used. I've never had one leak spark.
