Side mirrors
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
Yes it will. The side mirrors from 86.5-92 all attach without a problem. The only issue between the years is that Toyota changed the wiring connector for the mirrors in 89 (I believe, but I'm not 100% sure). So you may be able to screw on the mirrors from any year, although the wiring harness connector may not be the same.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
while the mirror plugs will not hook together, the pins match and it's all functional, so if you can find a way to hold the two plugs together (small ziptie), then you're good to go..
It's what I did for the 89 mirrors on my 86.5..
