Followed directions on this link...
http://www.supras.com/06/techcenter/techtips.php?category=MKIII
Mods: TMS 3" DP, Test Pipe, Blitz Nur Spec, Apexi Power Intake, aluminum DS.
So I shimmed the wastegate with 5 washers at each bolt of the WG actuator in between that and the compressor housing. Hooked everything back up, went out for a test run and only made 5-6psi:aigo: wtf!? I was making higher boost at stock set up (6.8ish psi) Wondering what is going on, if anyone has recommendations or suggestoins I would apprieciate it
Thanks
-Sam
Thanks
-Sam
