shim bucket dropped
Doward
4,245
Alachua, FL
drjonez said:
lifter? :confused: :runaway:
Shim bucket better? (Domestic upbringing dies hard) It's really nothing more than a solid lifter with removeable shim to adjust the camshaft's clearance... Valve lifters are technically camshaft followers as well...
Lifter/bucket/follower, I figure we're all on the same page, irregardless if the cam directly activates the valve, or if there is a pushrod in the way :D
For reference, I suggested that because the last head I pulled out of a 7M actually had the camshaft followers mixed up when the PO 'rebuilt' (I use that loosely) the head - not enough clearance, head heated up, followers expanded and a couple wedged themselves into place. It's a possibility for the OP ;)
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
ForcedTorque said:
I'd be sure of what"Voids" your warranty before tearing into anything
I purchsed the head from Dover Cylinder. All they do is rebuild heads for cars. A few local high hp supra guys have used them in the past and they are pretty cool here in the atlanta store. Im sure if I just take the head off the car without taking the head apart it won't ruin my warranty. But thanks for putting that out there.
Supra
304
Rockford, IL
I think I'd inspect it further. I'd pressurize the cylinder to prevent the valve from dropping incase the spring is broken (keepers will probably be loose when not under tension) and inspect from there. If it's just a broken spring and the valve hasn't dropped, I'd consider inspecting everything for damage/binding, just replace the spring and not say anything to the rebuild shop. If the spring IS all that's broken, why remove the head for a 5 minute repair? If the springs are stock, a bunch of us have spares. Know I can ship a few with ease. Don't drop a keeper or broken spring piece into the motor.
Good Luck.
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
Yea its certainly a 1st in my book.
Hey dr j what would you think is the cause? Poor workmanship on the shop? One of my pals suggested that I get them to double check the other seats before I take the head back.
supra90turbo
shaeff is FTMFW!
MA, 01440
If they're a reputable shop, as you say they are, then they should rebuild/replace the head completely to fully please the customer. To simply R&R the one would be outright ridiculous.
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
Yes I just dropped off the head and yes they will be doing the repairs for free. I will go there tuesday and pick it up. The owner said that if I want he has several other cores that I can choose from and he will gradly rebuild one of those if I prefer another head all together.
drjonez
the motor city
www.4cefed.com
hard to say. in the other cases, it's been for no appearant reason- i.e. not after being serviced....though for this case i think it is quite suspect...
bo3232000
Lurking in the dark
Jul 22, 2005
57
Cumming,Georgia
In regards to dover I will never use them to many horror stories...If you want a supra head that is rebuilt and preset to exact tolerances give Allied motor parts in East point GA a call and ask for Eric and tell him Scooby sent ya.....Great price and insane quality!!!!!!!Plus my uncle Russ owns it and i have grown up watching how and who builds the heads for him...Super great techs and many years of race proven reliability....The heads all have cams,all new prts and if i remember the price is I think 550.00 with core....:biglaugh: :biglaugh:
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
where were u several days ago? :) could have used that info then.. thanks all the same i will look into that.. any phone numbers? pm me if u like.
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
well i put her back together over the past few weeks. fresh rebuild and just dropped the motor in today with the help of will neely..
