Sheedy Built Supra
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
SPOOLINLUST;1932096 said:
Shouldnt, just pull your plugs and look for lean conditions and watch your FP. What AFR do you hit WOT 3rd gear?
I'm running a aem wideband so I know instantly if I'm running too rich or too lean
I was getting around 13+ afr at wide open throttle around 3500ish rpm so I let off. Just taking it easy cruising until its properly tuned for now
Sent from my PC36100 using Tapatalk 2
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
bad day when i went to go to Kennys house to tune
we hooked everything up to his laptop, started tuner pro rt, and started to head down the road. once on the road i put the pedal to the floor to do a log on the laptop, but wouldnt build any boost at all. the turbo just makes a whining noise, kind of like running a coordless drill. so i didnt get any tuning that day
no pre-tubo exhaust leaks and am going to check for boost leaks/codes soon.
another thing i noticed today was the compressor wheel was scraping the housing a little.
could this cause the turbo to get slowed down and not build boost after it heats up and expands?
IndigoMKII
2,181
Madison, Virginia
If the compressor wheel is touching the compressor housing, stop running this turbo, PERIOD. It is already causing irreversible damage, if you keep running it you risk shattering the wheel and tossing the blades into the intercooler.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Well, I think it is the turbo, I've narrowed it down as far as I could and looks like that's the last part that is acting up
Time to send it to a quality turbo rebuilding shop. Has anyone tried alamo turbo in Kent,wa? Or maybe Albert
IndigoMKII
2,181
Madison, Virginia
Albert quoted me 200 bucks to rebuild my hx35. Which is a very fair price and he's extremely recommended by the SM members.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Awesome. I'll have to message him.
Although I think I may need a new compressor housing and definitely a new wheel
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
yep, i had it rebuilt by a buddy of mine and it worked fine for awhile but im guessing he didnt rebalance it
ill get it done by a good shop this time
Grandavi
2,664
8
Calgary, Alberta, Canada
I don't think they actual do the work, they just handle the transaction and have a turbo builder that services them (from what I understand). More of a "give it to us and we will handle it". Their builder is supposed to be good though.
SPOOLINLUST
68
nnj
Sounds like he didnt mark it correctly or install it correctly. That sucks man!! Clean that intercooler rreeeaalll good you definitely have some metal in it now!!
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
yeah, thats alright. this new turbo should be more than enough for my power goals. plus some!
i decided to go with the 62mm billet wheel
good thing i have a new intercooler to install, i think im going to get that installed before the new turbo goes on.
cant wait!
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
bloodasp90;1936499 said:
hey, if you dont mind me asking, what are your fuel upgrades at? what kinda injectors and pump are you running on your system?
im running a set of rc 550 cc injectors and a walbro 255 fuel pump
