Sawblade stripping
steeven001
30
Toronto
First I sand blasted them without the tires on of course to take off the paint. Then sanded down the machine lines with 200 grit sand paper then worked my way up with wet sanding. 400, 600, 800, 1000, 1500, 2000 then applied mothers powermetal aluminum polish with the mothers ball mini.
Only thing is I wish I clear coated in the holes and fins where I couldn't polish. Brake dust sticks to them so easy so I usually have to wash them thoroughly by hand weekly because the powerwasher doesn't blast it all off and I don't use wheel cleaners because they might cause the polish to go dulll. But all in all the shine lasted all summer and now I'm washing them and putthing them away for the winter as I use snow tires with seperate rims in the winter. Then when I pull them out next summer I'll polish them again.
Car is a 89 Cressida if anyone is wandering. And center caps are now all black.
steeven001
30
Toronto
It doesn't cost much to do. I spent about $40 to do all 4 wheels. But the amount of time I took must of been atleast 12 hours but hey I got a lot of free time anyways so I just did like an hour here and there over a span of 3 or 4 weeks.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
You spent too much, melt them for aluminum.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
WAAAAAY too much work!
I am going to reveal a little secret weapon I use to make short work of polishing aluminum to an absolute mirror shine. Using my process you should be able to take a fully original sawblade and make it shine like chrome in about an hour.
First thing you need is an angle grinder. Harbor Freight sells one for less than $30, but my local favorite store Bi-Mart sells one for $25 and Ive had two last quite a while and come with a spare set of brushes.
Next thing you need is a backing pad that will fit on the angle grinder and has a hook and loop surface. On that you are going to use 3M Scotch-Brite™ Surface Conditioning Discs. They come in 4 grades, from coarse to very fine. Get yourself 2 of each grade, Brown, maroon, blue, gray. That will be enough to do all 4 wheels. They look like this: picture link
Lastly you need a cotton polishing pad that will fit on the same backer. They look something like THIS. And a polishing compound to apply to it. The Polshing compound is kind of wax like and comes on a stick. You can find them at HD and Lowes as well and you want the #6 compound and looks like the #6 stick in This kit but is about twice as long. (dont buy this kit, just get the compound seen in it)
The process is simple. Start with the coarse pad and stip all the paint and machine marks off the wheel. Use a light hand or you WILL create divits as this stuff cuts fast when spinning at around 13k RPMs. A good once over with a light hand should have the wheel loooking like you just spend hours and hours sanding with 400grit. Work your way through each compound. All you need to do is removed the previous pads scratches. Since you are working on a fairly flat surface its pretty easy and nice smooth strokes across the face works best.
Dont overwork any particualr spot and dont use too much presssure or you will wear out the pad prematurely. ALSO, be mindful of sharp edges (like the center cap area) and the direction of pad roatation. ALWAYS make sure the pad rotation is going towards the hole and not against it or the pad will grab, and tear it up and possibly yank the grinder out of your hand.
After you have used the gray pad the wheel will be very shiny and should have a fairly even looking surface. If you REALLLY want a mirror flat and shiny surface you will want to insert one extra step at this point. However this can skipped and you can move on to polishing now, and your wheel will shine like chrome still, but it wont be PERFECTLY flat. If you want a glass smooth wheel just wet sand with 600grit wet or dry sandpaper on a sanding block. It really doesnt take much work and what you are looking for is to just reduce any high spots you might have left after using the 3m pads.
Either way, the next part is where the majority of the time savings takes place. Forget the whole 800grit, 1000grit, 1500grit, rubbing compound, polishing compound, final buff Bullshit. Its completely un-neccessary.
Mount up the felt polishing pad on your grinder, while its spinning, apply the wax like #6 compound to it. It will make the pad green. Being careful to always work away from any sharp edges and not towards them, begin to apply the compound to the wheel. You will be amazed at just how fast the wheel will turn from a dull gray to a mirror. Use a heavy hand at first and then lighten your touch as it begins to shine. Apply more compound as needed and you can also wash the felt pads if they get choked or glazed, or just spray a little mist of water on the area you are working on.
Once you get the technique down it should go a little faster. From pulling the wheel, through grinding and polishing and final clean up to remove any mess on the tires, etc., and remoounting the wheels on the car, shouldnt take more than 6 hours with beer breaks.
This same process can be used on intake manifolds, valve covers, and even steel parts. I have made steel look like chrome, just be sure to clear coat steel afterwards to make it stay shiny. The 3M pads can also be found in a 2" version to put on a die grinder for smaller tighter spots.
So thats it. Using this technique I have cut down hand labor on polishing DRAMATICALLY and it allowed me to even sell my service and make decent money doing it. Is there an investment involved? yes, but if you want some shiny parts for you car (beyond just your wheels), or want to even make a few bucks doing some polishing for buddies, it all pays for itself in a very short time.
cuel
1,536
Baytown, Texas
The top metal piece of the center cap comes off fairly easy. You can strip and polish it without tearing up the plastic that way. I don't quite remember how I did it, though. I'll have to look at them again tomorrow.
aidanair
Cops Love Me
Aug 27, 2007
63
Marlboro
wait wait.. you used the aircraft stuff on your center caps? there not chrome underneath lol when u strip the allow paint youl just have......plastic.. you painted chrome over it?
cry4me_sky
129
selah
wow! thx a lot man.
well me and dunckel went and got my dads angle grinder from the carwash adn bir-mart was closed, we looked at fred meyers and wal-mart and couldnt find the right attatchments so im going to go look tommorrow.
i got a can of nevr dull, and i used a drill attatchment with some 600 and the 1500 sand paper and its working pretty well. two whells are about ready to paint and the other two are outside sitll on my car.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
you mean Never Shiney? I used that stuff AFTER I polished a manifold once and all it did was make it dull again.
If you dont have a home depot or Lowes nearby Bi-Mart and I am pretty sure walmart as well, sells something similiar to the hook and loop backing pad and some of the surface prep pads in a set. Look for a yellow package that has three disks in it that are brown, maroon and blue/green (they dont sell the ultra fine but most of the time you can get away without it). then get the backing pad they recommend for those disks.
The only problem with that setup is that you wont be able to get a felt pad for it (at least not that I ever found). and to be honest the felt pad and the proper compound is what makes all the difference in the end result.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
Ckanderson said:
ill be trying this to strip the rust/paint off the lincoln.
To be honest Ck those pads arent that great for paint, but do a good job on rust on bare metal. If youve ever used those green scotch-brite pads on an aluminum cooking pan you know how they make quick work of scum and stuff. Paint however tends to clog them very fast.
The paint on sawblades isnt that thick and its usually pretty dry and ready to flake right off anyway.
ValgeKotkas
2,224
Over the pond
Damn, Weezl could've wrote that like a year ago :D But still... yeah, I'd have very hard time finding those pads and stuff here I guess. :)
But still, maybe I'll use this technique sometime :) Thanks.
