san supra;2043846 said:hmmm mine stays lean until 10psi
i have all of those things except the afpr installed
S.A. supra i have the eibach tokico set up and it lowers the car but for performance id say its pretty weak.
If you're rolling on the throttle into boost TCCS will not immediately go into open loop. If you were to go full throttle say around 2000rpm and watch it build boost, what will your afr's do while boost builds? I would think your car will go open loop sooner, and you'll be running rich well before 10psi, right?
