Ryan's 92 build thread aka NashMan
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
suprarich;1724431 said:
Looking good. Is that some redline assembly grease I see?
indeed there rich on the lube and lucky is good beer toby just has no taste
as of right now I am fitting the Teflon seal feet are getting sore stand aroud a trimming is so fun
Cool, it's a PITA but you only need to do it once!
I also found using 4x flat (2 at each end) washers the same thickness as the scraper rails on the front and rear cases gave a much better seal with RTV as it stops the pan distorting.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
yae that was my plan ian because i have steel stamped pan so it will bend easy
on a side note
was installing my buckets and shims today and found out i had very sticky bucket so i made this tool and spun it with a little bit of assembly lube
might have got tiny bit tweek when she got welded
good to go now thou ( warning to other people never hone these with a stone or file since there anodized) what i did was tad different
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well whent back and worked on the head and shorted out my brake lines just uni set with adptors cost alot less then buying a set made for the car
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well head is done i all ways find it faster to do it as a team makes shit allot faster
painted my block
clarence my oil pump pickup some as well it about 1/2 to 3/4 from tube to floor
oh and i went to put my oil pump gear on and found this this is factory as well so i de bured it with a die grinder and then sanded it away to prevent it from cracking
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well some time has past my heag gasket came in and it was not bent this time woot woot
stuff
done brake lines fuly install
long block complete
msd window switch fully installed
replaced my acsumspe vavle the old one was leaking
what to do today install more make a crank stop jigg so i can torq down my blacer then install trans and then build a new down pipe busy week end for me
on to the pic's
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well fair amonte got done yesterday engine/trannie/rad is in and lots of miss stuff bolted up
pic's
now all I have to do now is build down pipe and send it off to be coated since i rushed my last one and did not fit all to well
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well got more stuff done
but skipped on the thermo coating since knowing my luck all never get it back in time so I just re wrapped it
I made a new down pipe this time around witch fit's and flows a tone better then the last pile of rushed shit I made
here is my old down pipe
NashMan
Aug 5, 2005
4,940
17
Victoria BC
3 1/2 to 4 inc to match my exhaust
but today I am going to fire her up
sad part is I can not get any nitromethane here in Canada far as I have found out
for my Rufe cocktail mix for my meth injection
so it will just have to be a 50/50 mix
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well no fire up today i still have to make a dip stick
But I am going to break it in way that is really never mention here on sm
I going to break it in with no waste gate so no boost so I can beat the piss out of it to break in thous molly rings
I fabbed up a make shift tube off my manifold with sc40 poo pipe with the spare flang i had
then after about 25 mins of driving stabbing the throttle a bunch of times drain oil re install waste gate re torq head then off to get her tuned
NashMan
Aug 5, 2005
4,940
17
Victoria BC
hummmm i have no oil pressure hummm even after manual priming one of my oil lines off the oil relocation
i did take the cover off the oil pump but i torqed it back to speack i hope to hell it's not leaking grrrrrrrrrrr
