Running a 7M without the Coolant By-pass Tube
Txsupra;1392339 said:
Some how I knew you'd say that. However since my car will will only be going a quarter mile at a time and maybe a few times down the street and back, mile or so. Do you still think its necessary? Asking for the crowd as I now plan to put in a hose. Also why would it cause cavitation? Is is because of system design? Isn't it the same setup as an N/A but with those bosses tapped for the hoses? Trickle valve isn't enough to keep pump from building pressure? Makes since to me but I must know why in order for the info to stick
It won't build pressure it'll cavitate while the T Stat is closed.
Up to you it's one hose and a couple of clamps to do it correctly.
mk3ukr
292
Odessa, Ukraine
mk3ukr-supra.net
IJ.;1392241 said:
There is a 30c degree difference in head Temp on an idling 7M front to rear so ANYTHING that helps reduce the rear of head temp can only be a good thing.
Ian, how did you measure it, with infrared thermometer? I knew about rear part of the head running hotter, 30C seems a lot.
The best to help cylinder head cooling is to run heater on full blast on the track.
I have electric water pump in the lower radiator hose and now think it would be good idea for me to reroute heater line to upper radiator hose.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
jdub;1391335 said:
Also, the heater control valve never completely closes...there is always a small flow through the heater core. If you remove those lines though, it will not really matter.
I checked on this.
It's VERY tiny. ;)
Also, on what IJ is talking about, the N/A has a bypass as well if you wanted to swap the t-stat housing and clean it up.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
The person I got my GTE from had the coolant bypass tubes modified to cut out the heater circuit. Here's a pic of the modified upper tube, and blocked off lower tube.
(I still have the tubes, and I'm open to offers if you want them).
