KevinM;1517392 said:I had mine done a couple of years ago and prefer a little smoother cowel like this:
-it's another great option to have though either way!
(front is high since there's no motor in it right now)
Where did you get yours done at?
Chambers;1518044 said:I like it! As for the radius of the slope, I think it should be smoothed out a bit. But for my future plans with my project, a higher cowl will make more room for a twin scroll supercharger sitting on top of my engine. Also, any chance for windshield washers to have a home on the hood?
I would like to see the framing on the bottom though! Good work, keep it up!!
Buckweed;1519868 said:unless it looks like tekdues' im not buying id rather buy a stout
YoungGunSupra;1520137 said:lol might as wlel just make a whole kit to make your car looks like tekedus's car. but yea id be in for one depending on price. you can paint it to match the stock white paint that went on the 87 supras?
M_31_07;1526516 said:That hood looks very agressive, I like it!!! Why would you buy a cowl hood in the first place if you were looking for a subtle look? If that's the case just stick to the OEM hood. Depending if it's raised too much then yeah, but this one you have right now Paulo is great. Put me on the list when this comes out, I'll be on the look out.
boricua114;1526580 said:The reason is to cool the engine more, some drag mk3's put spacers to make the back of the hood be up higher so more heat can escape
supramk3speed;1526888 said:I have actually seen testing done that shows using spacers at the rear of your hood does increase cooling efficiency. Im not sure that i would go to that extreme for a few degrees of cooling, maybe on a vehicle used in competition.
Whats the progress on the hood?
IJ.;1526897 said:As Jamie said base of the screen is a high pressure zone so it's going to act as a brake for any hot air trying to escape once moving, when stopped though it will act as a chimney and reduce temps (we've been discussing this a LOT for my car with the over the engine header routing)
