replacing hub studs need help!
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
hello, i need to replace all 5 studs on the driver side front wheel, i know the tsrm has a special tool to remove them, but most of them are broke off almost even so this is a 2 part question
how would i remove them if broken flush?
or should i get a new hub and install new hub bolts (reqires removal of the whole hub assembly off the car and to use a press)
input is greatly appreciated
they pop through and then are insered from the back, use and open ended lug net to pell em into place...
very easy if you don't have ABS...
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
Just hit them through with a punch.
Then put the next one in through the back, be sure to get it straight, and put a bunch of washers on the hub face and use an open ended 12 X 1.5 mm nut to pull the knurl into the hub holes
DON'T OVERTORQUE, stock lug nut torque is fine to seating them, anything more and you'll stretch, damage, or snap the bolts...
MA717MGTE
boostaholic
Apr 2, 2005
404
Bristol VA
thanks ill try the punch idea!
Satan
Tampa
Getting ready to do my 91 (with ABS)... anyone have some timesaving tips, write-up? My 87T had ABS and I don't remember the front wheel hubs being this difficult to work with.
I don't want to pull the whole huib off if I don't have to (got lots of other work that needs my more immediate attention).
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
all i know is i replaced ONE stud on a buddies 89T with ABS and it was a bitch!!. i will buy a new shell before i replace one of those in my car again LOL
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
LOL!- TRUE that.
I've replace all of the front studs in both hubs, because I replaced both front bearings/ seals. It IS a bitch to disassemble the ABS hubs, because that big-ass nut on the back doesn't wanna come off without airtools, and the spindle itself will NOT come out without an SST, or a very creative way of placing it in a press. I then pressed all of the new studs back in with the press- easy.
PS- If you have to get new wheel studs, DON'T get them from Toyota- they're like $5 each! I paid $7 total for 5 studs at Oreilly's.
