hello, i need to replace all 5 studs on the driver side front wheel, i know the tsrm has a special tool to remove them, but most of them are broke off almost even so this is a 2 part question
how would i remove them if broken flush?
or should i get a new hub and install new hub bolts (reqires removal of the whole hub assembly off the car and to use a press)
input is greatly appreciated
