replacing clutch 'n stuff - pull engine?
jaxtaterror
31
jacksonville, fl
Hi Guys.
Need to replace clutch, flywheel, and leaking rear main seal. I'm thinking it would be easier to pull the engine and trans together then just the trans. (I've pulled them out before and have all the tools)
Am I crazy? I used to have a link to an engine pull check list - anyone have one for reference?
Planning to go with South Bend OFE Street Series Clutch Kit and Fidanza flywheel - would appreciate any comments/suggestions here as well.
Thanks,
Don
a_sesshoumaru
Suprita
Jan 7, 2007
455
El Salvador
i would only take the trans out, it`s a lot easier than taking the whole motor out, to take the trans out you just need to remove the shift knob and stick, remove the pressure plate bolts throu the inspection covers, the fork and the mount holding the trans. That`s about it.
Edit, plus the driveshaft bolts and block to trans bolts.
toy fanatic78
addicted to toy's
Oct 17, 2008
689
Elkhart,IN
I too would pull just the trans,it's not that hard.The only bolt hard to get at is the top one for the starter.
*drain trans
*remove interior panel(console)to remove shifter
*remove driveshaft
*remove speedo cable,and back-up light switch(connector)at trans
*trans crossmember(support engine as it will tip down when the brace is removed)
*bellhousing to engine bolts,tranny "wings"(braces),and starter.The top two trans bolts are easier to get at with the engine/trans tipped down slightly
*remove trans and there's your clutch
This is for a W-58,not sure how much different the R-154 is.
nosman4
133
Bend, Oregon
Are you removing it on jackstands or up on a hoist? If you have access to a hoist I would just pull the trans, so much less work.
Torquing everything is just as easy with the engine in the car.
Most people have issues getting the tranny lined back up, if you have a tranny jack (like I do) it's MUCH easier to pull just the tranny.
Mk3runner
2,033
Nor Cal
Turbo trans alignment is a snap, upper bolts is a bitch. I'll always pull as a unit. Trying to gut a trans in sucks.
Mk3runner
2,033
Nor Cal
Tranny jack ftw. But I don't have one and a good excuse is better inspection when pulled as one. LOL sounds good to me at least.
Taking the interior apart to get the ECU disconnected, removing the wiring harness without breaking it (hard), and much more shit to disconnect...
if your time is worth money, buy the damn jack LOL
Mk3runner
2,033
Nor Cal
Very true on the the glove box and shoving old harness is a bitch.. Tranny jack at local harbor freight I think was 89 last time I checked.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Guys, it's simple a matter of time.
Pulling the engine / tranny as a combo to replace the clutch, then putting it back in takes me at the least 2 days with 2 experienced guys.
Pulling the tranny by itself, replacing the clutch, and putting it back in takes me at least 4 hours with 2 experienced guys.
Do the math: 25% of the time and effort. Leave the engine in the car unless you need access to it as well.
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
+1
Now if you were replacing the clutch on a civic pulling the hole motor is the thing to do. I had it down to 45mins, engine out on the floor, by myself with the old hatch back. RWD MUCH more room to move around, and once tranny mount is removed it can be lowered down slighty to make more room. Just dont cut off the heater core hoses against the firewall.
jaxtaterror
31
jacksonville, fl
OK guys - thanks for all the input. I'll get a tranny jack and try it that way. At worst, if I can't get lined up on install I'll pull the engine then.
I'll be doing the job pretty much by myself - my girl will hand me wrenches and stuff, but she's not gonna wrestle with a transmission!
Is this the HF tranny jack you were using, Poodles?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=39178
$89.99
Saddle tilts for easy positioning
Lift range: 7-1/4'' to 23-1/4''
Cradle size: 6-7/8'' x 13''
3'' non-marring swivel casters
Maximum capacity: 450 lbs
Mk3runner
2,033
Nor Cal
I put my trans up by myself.. With the inspection covers off you can almost fully see where the input shaft goes.
