Replaced Auto trans and wont go in gear!!!
Yeliyayue
8
longview, wa
I have a '87 supra auto, the tranny was toast when i bought it, so i just put in a tranny yesterday but the tranny i put in only had 3 of the four plugs comeing off of it!! after i got it in i tryed starting the car nothing happened, so i spliced 2 of the 4 wires on the engine side of the missing plug(i made a educated guess) and the car fired up but it wont go in gear. i tryed searching the forums for a answer but i came up empty :nono: anyone got any clues as to whats going on?
the shifter is hooked up and it clicks through gears, and i put oil in the tranny:icon_bigg
heres a link toa pic i found on the forums http://www.supramania.com/forums/showthread.php?t=112561
its the 4 wire square plug thats missing on the tranny.
Yeliyayue
8
longview, wa
its in park, its starts up now. and its has plenty of oil. i shift through the gears and nothing happens it no noises or anything, but it is hooked up and clicking through the gears. does anyone know if that missing plug that i spliced to start the car is my problem? what do the other 2 wires on that plug do? and why doesnt the tranny have the 4th plug? dif year of something?
"plenty of oil"???
Where is it reading on the dip stick with the car at operating temps with the engine running in park?
The trans "should" shift 100% on just the shifter even if everything is unplugged.
Usually if you put it in gear and it won't move it doesn't have enough Oil, these Auto's are fairly bombproof unless it's a million miles old or the screen is blocked solid they'll work.
Yeliyayue
8
longview, wa
we put a new filter in. the old one looked normal, had some very small particle in the screen no metal chunks and the magnet in the pan had a sludge film on it also no metal chunks. I was told at the auto parts store i need 1.9l of oil so i put 1 and half quarts to start off cause i didnt drain the torque converter when it was out. the guy i bought the car from wasnt very smart, and he lost the dipstick.... and the new tranny didnt come with one. so should i risk over filling it and put half a quart more in?
ROFLMAO @ 1.9L of Oil :D
put another half a qt in dip it running then repeat as many times as needed :)
(get a dip stick)
Welcome Dude!
There's no real way of knowing how much Oil came out when you dropped the pan as these things will keep dripping for a month after the pan is off!
A total dry fill can be around 5>8 litres.
Dipstick is the only way to accurately fill it.
Yeliyayue
8
longview, wa
sweet its driving awesome! im gonna go down to the junk yard and get a dipstick. im hopeing the other 2 wires on the plug i spliced to start the car just run the reverse lights.
toyzforme
I need deeper pockets
Jan 1, 2008
103
Summerville, SC
Why can't you take the dipstick out of your old tranny?
