removing the 1J head
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Sticky here http://www.supramania.com/forums/showthread.php?t=36448
supramk3man
414
kentucky
It isn't to bad to remove just make sure you get the allen all the way in the hole and that you don't twist anything off.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Finding a 12mm 12-point allen is kind of difficult. Well it was for me atleast. I had to borrow one from a machine shop. Couldn't find it at Harbor freight, Sears, Napa. Got some at Pep Boys but the head bolt shredded the teeth.
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
so it's a 12mm not a 10 like it says in that translated manual?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
It said the same thing in the 2jz manual but my 2jz was a 12mm. Again buy that tool from Snap-on or some other high end tool dealer. I shredded the teeth on a Pep Boys brand 12mm 12 point torque.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I ordered one from toyota japan. That was a fail :(.
I found a set of the 12pt allens in summit's tool catalog. For much cheaper than I payed for the one socket.
Edit: my boss threw away the catalog so I don't have the part number.. if you call them I'm sure they can look it up. I can't find it on the website.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
hrmm i didnt need a 12 point socket removed my stuff just fine but i guess its hit and miss
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
lol neither did I the first time. Infact I didn't even notice it was 12 pt until the head was off.. then i was very thankful. The second time i tried to wing it and stripped out a headbolt :cry:. I drilled at it for about 5 hours before it popped off.. nothing like learning the hard way :sarcasm:
bobiseverywhere
bobb'n for money
Montreal
Ouch! thats all i have to say
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
5hrs? Took me about 10 minutes to drill one out that I fucked up :dunno:
