Rear window moulding removal
Chard
62
Fairfax, VA
Just want to ask anyone that had replaced it on what tool you used. The right side (the one that goes vertical if your looking from the back side) is messed up and I want to replace it since water is getting in there.
Also is this item still available from Champion Toyota?
Thanks.
shaeff
Kurt is FTMFW x2!!!!
9
Around
I used a set of my friend's trim tools and took my time. They work like a charm. :)
Also, I'm pretty sure they're still available. :)
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Are you talking about the stuff that surrounds the front windows, or the actual rear window? My trim around the front windows is all screwed (especially the rear pieces) and I was also wondering how you remove those.
kHaNg
Like FAtHer Like SoN
Apr 17, 2007
177
Mass
if its the one right where the door is you must open the panels inside where the seatbelt is.
Guyana00
Droppin that JZ in soon!
Apr 18, 2007
1,208
Brampton, ON
I believe shaeff has the right idea, because I also think that it's the same window trim you're talking about (rear windshield, passenger side).
For me, I just pry it up from the end, get a hold of it and pull it out. Clean the area out and replace the new strip with some urethane. Worked wonderful for me, several times (different cars).
