r154 or w58
toyo prformnce
14
Cincinnati, OH
i recently bought a turbo automatic supra. i have a parts supra also that i achually used to drive. its a 5 spd NA.
i know the turbo motors come with a r154 for a 5 spd, but i've been told the w58 tranny will bolt up...
i know the w58 is not as strong, but i would like to know if it would bolt up... any help would be nice...
thanks
shaeff
Kurt is FTMFW x2!!!!
11
Around
what exactly are you doing? replacing the r154 with the w58? if so, just swap trannys and associated parts. no need to mess around with ECU's.
-shaeff
Boostedstr8six
I have better SA than you
Near Columbia, the river
The W58 will bolt up and having a complete parts car will make the swap a lot easier. There is a ton of info on auto/manual swaps here and SF. I would want to get an R154 parts car if I had to do the swap but the W58 is right there....
Man, you guys need to learn how to read...lol He has a Turbo Auto and wants to go 5 speed.
1TuffSupra
Sho' Nuff
500
Raleigh, North Carolina, United States
No shaeff he is talking about swapping his auto equipped turbo supra with a w58 from a NA parts car that he has.
But do just like shaeff said and swap everything over it will all bolt right up. Im not sure whether the ECU will need to be swapped, but I kind of doubt it. You will probably just have some wires that plugged into the tranny that you no longer need
shaeff
11
Around
oh i see. :) yes, the AUTOMATIC ECU will work fine with the 5 speed transmission. :)
-shaeff
Afunk
53
and for the computers it doesn't matter, just splice the connector that corresponds to your tranny on
Boss302
249
Mobile, Al
i would recommend changing the ecu though cause it is different from the manual tranny if i remeber right don't know for sure will get back to ya on that though.
shaeff
11
Around
i'm running (if i remember right) an automatic ECU in my turbo swapped N/A chassis, with a w58. everything works fine.
-shaeff
toyo prformnce
14
Cincinnati, OH
thanks fellas... the car thats now the parts car was actually auto when i bought it, but i 5 speeded that shit.. i know about all the ecu stuff..
i just wasnt forsure if the w58 would bolt up.. but now i know it will
thanks alot...
