Question for the pros
airhead04
1,489
Lima, Ohio, United States
I need to change my oil pressure sending unit and cant decide on which one. I was thinking of just buying one from toyota for my 7m, so its like the old one, but, I found one at Prosport gauges and it has an oil gauge and an electric opsu.
So I just wanted a pros point of view. Anybodys point of view actually. Thanks for the help.
Sorry mods if this is in the wrong section.
airhead04
1,489
yes, opsu is an oil pressure sending unit. I just got lazy and didnt type it out. Well my oil pressure has been acting weird so, Im going to start fixing the small before I have to tear down the engine. Im hoping that its just the oil pressure unit.
So go with the prosport gauge and pressure unit...or just buy an oem one?
They both cost the same.
toyzforme
I need deeper pockets
Jan 1, 2008
103
Summerville, SC
Just remember the thread pitch might be different. I installed a Autometer oil pressure sending unit and it leaked a bit. Then I found out on the other forum that the thread pitch was different and I had to buy an adapter from autometer. Have not put in on yet as I am deployed in the desert. It is on the list of things to do when I get home.
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
There's an adapter on Prosport's website that you'll need to buy if you want to use their sending unit in the stock location. The adapter costs about $10.
supra90turbo
shaeff is FTMFW!
MA, 01440
You're better off getting an oil filter sandwich adapter and putting the aftermarket gauge sender in that and leaving the factory sender in place.
Supracentral
12
^ This ^
Or put the aftermarket sender on a M/F adaptor and screw it into the forward port, I did this when I still had my stock dash and wanted the MoTeC to have fast accurate OP input.
