question about single versus twin
SupraClaou
846
4
Athens,Greece
Speedforsale.com has a twin-turbo set up for 2jzgte that is working in
sequential mode (factory/oem mode and looks):biglaugh:
Two GT28R turbos in the stock CT12/CT20 Toyota housings!!!!
This kit in the sequential mode can go up to 550 rwhp!
This should be amazing....while you'll get turbo wine before 2000 rpms and
no lag at all :love::biglaugh:
figgie
Twin Cities, Minnesot-ah
two GT28R and only 550rwhp? Hmm. Sounds like they are being choked to death (ie stupid high turbine speeds and not enough room to let them breath and probably to the left in the efficiency islands for both). 125k rpm turbine speed, choked to death.............I wonder how long that setup is going to last.
OneJoeZee
Retired Post Whore
aboard the Argama
sparkplug619;1198078 said:
you think i would be able to make up for these lost numbers with 2 decent sized/ rated upgrades? i wouldnt mind a big single either though, i just liked the look of the tt but i didnt know it was a crappy setup... thanks for the support suprahero... btw my girlfriend just fell in love with that pic of ur interior like 2 minutes ago lol1
Twins are not worth it. Just go single. Get over the "omgz, two turbos!" thing. But that's just me. I tried it and it was fun while it lasted.
OneJoeZee
Retired Post Whore
aboard the Argama
That said, if/when I have another 1J supra, I think I'll leave the stock twins in there.
I enjoyed the car alot more with the stock twins...
SupraClaou
846
4
Athens,Greece
Yeah...that's true.
And 550 rwhp on race gas + 26psi!
They do admit that there is restriction on air flow. They estimate that with
some more supporting mods like cams,ported or custom exh. manifold,ported
head,3"+(maybe 3.5") exhaust/DP,and quite big free flow IC + pipes ....could
give you some more whp. For sure more than 600rwhp and still having the
stock sequential mode!
I wonder if someone has this setup with those supporting mods! :biglaugh:
jizake1jz
FTMFW
Feb 18, 2007
146
Lake Zurich, IL
550 hp? i thought thats pretty good for twin gt28r's. they aren't rated that high....
i want to get over the "omgz, huge turbo!" thing. i have an sc61 on the car now anyway. its not about the "wow look big twins," i want it to be "wow look at all the nice fab that went into making this setup. look how nice everything flows together and fits well into the given space. AND it make respectable numbers!"
but i also don't want to spend a ton of money on something that isn't going to work properly, which, from the above posts, doesn't seem like it will. anyone can buy the parts to bolt on a big turbo, but i want to be the guy that learned how to make all his own parts to try something a little different then most of the rest.
basically, will it work? will it be the worst choice i ever make? i honestly don't know, thats why i'm asking, but i want to put up a little argument so as to fully discuss the topic :D
AND if you had to go larger twins, which would you choose and why?
LordDigital;1197987 said:
5 Years after Toyota Introduced the Twin Turbo 1JZ ,they officially admitted that a plain Parallel twin turbo setup is WORSE than a Single turbo in the following article
Now for a more sophisticated Twin Turbo setups like the USDM 2JZ-GTE or even on some Audi(s) the story is quite different.
dude,
That article was awesome!!! I havent seen it before.Thank you very much!!!
OneJoeZee
Retired Post Whore
aboard the Argama
It is for this guy.
sparkplug619;1197732 said:
because i like the whole idea of twin, the way it hisses, looks, and especially would love to brag about my twin turbocharged car.
figgie
Considering that Garrett rated the GT2876R at 480 hp.... two of them should be able to do 700 easily. But we get into that efficiency thing again ;)
Gritz
155
nc
I wasn't suggesting that twins are better..i was just saying.. do your home work..then make a choice....And if the twin look is really what you want..go for it....Its more of a hassle with twins so keep that in mind...
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
I am doing one as we speak. Should be fun..... I hope:x:
jizake1jz
FTMFW
Feb 18, 2007
146
Lake Zurich, IL
yes, buts thats a gt2876r, not a gt28r. as far as i know, a gt28r is just another name for a gt2560r, which is way smaller than a gt2876r.
you also keep saying efficiency. what do you mean by that? is it just a direct relationship with flow in this case? the stock 1jz came with twins. i don't understand how using bigger twins won't work well. sure it will be way different than a 42r(which as you said, i found to be a really nice match for the 1jz when i first started comparing a larger single to large twins), but a nice set of twins will flow better then the stock turbos, and i hope have power at a decent range. i never looked into it, but what is the powerband like on a 42r? i want something that can be used elsewhere besides a dyno and the dragstrip. thats why i thought a twin setup might make nice setup
88supraTT
292
around the bend
friggie thanks for response
here is a graph that i found digging for info. i understand the 1jz is at a huge disadvantage because of the displacement of the engine and which is why ive been going back in forth about what turbo or turbos to run ever since i decided to go with a 1jz in the fc.
note: I'm pretty sure this is a 2jz
jizake1jz
FTMFW
Feb 18, 2007
146
Lake Zurich, IL
nice find on the graph! what do you make of it though?
EDIT: wait, is that twin gt28rs's? it looks like the only difference is spool time really, otherwise almost identical. this is very helpful
88supraTT
292
around the bend
I'll see if i can find the thread, but it shows the gt40r is producing power sooner in the rpm band, is alot more aggressive coming on and is also creating more peak power.. versus the twins are a little more linear don't create as much, but also are not as agressive when fist starting. which is what i think will be better for auto cross. its hard for me to make decisions because i only know one other person with a 1jz in the area, and only know one other person..my brother running a large single. so all the information for me has to found on the internet.
