question about r154
SupraBro
so i have a 88 7mgte and i am trying to bolt my trans back up, i dont have a lift:: angry ::..i have my car up on 4 stands, i lifted the motor from the front to tilt the back down but i still cant get the trans axle to slide in...the top of the bell housing is hitting the car....do you guys have ant tricks to do this...or a link..i had to put the motor back in without the trans...because i only had the lift for a short time and i was waiting on flywheel...thanks for your time!!!
Do you already have your clutch mounted to the flywheel? If so, take it off, slide it onto the input shaft, install tranny and then bolt it up. If you don't have the clutch already mounted to the flywheel, you're not holding your mouth right.
