I will go back over this for accuracy when I get home this afternoon.... Do not consider this post finished and hold your questions and comments until I do finish it!
Well, assuming that you wanted to just start out by getting something installed with less restriction and that's tunable, but NOT take advantage of AFR tracking features you could go with a MAFT Pro and a LS-1 MAF or a MAFT Pro and SD without a wideband installed on board.
In both cases I would recommend at least borrowing a wide band to install temporarily for two reasons:
1) As noted in the writeup the LS-1 3.5" MAF isn't entirely accurate when installed using couplers to connect it to the 2.75 intake piping. This can cause you to run VERY rich at WOT and other instances where the ECU isn't tracking for 14.7. When I had my 3.5" MAF installed a couple dyno runs revealed my AFRs at WOT to be in the low 11's.... :3d_frown:
2) With a Speed/Density setup you need to see accurately what your fuel is doing when the ECU is in closed loop (such as when you're at WOT). You also need a wideband to accurately adjust for your tip-in... this way you don't go rich as hell when you first step on the throttle or you don't go
rich or lean when letting up making the car buck or lurch.
If you're going with a MAF you could go with a smaller unit that won't require as much or any reduction. This way the ECU is getting an accurate measurement.
So, you would:
1) Build your own harness using the supplied pigtail from the MAFT Pro and connectors for sensors from a junk yard or parts store. Alternatively you can buy a SD harness for the SD setup for very little, but no premade harness is available for the MAF setup at the time of this post.
2) install the MAFT Pro and the MAF (or MAP sensor and IAT sensor)
3) connect a wideband and disconnect the stock O2 sensor
4) tune the system across the board (keep Vf fuel trims in mind here)
5) remove the wideband and reconnect the stock O2 sensor
Prices:
MAFT Pro with 3.5" LS-1 MAF:
MAFT Pro -
$399.99
LS-1 3.5" MAF -
$109.99
Couplers - Slilcone reducer 2.75" to 3.5", you need 2 -
$12.99ea
Intake piping - Civic CAI kit or whatever you like $25+, depending on the kit more couplers may be required.
Air filter - Get a good filter dammit... Up to you though... the intake kit may come with one.
MAFT Pro with 3" LS-1 MAF (Best bet for a simple install):
MAFT Pro -
$399.99
GM 3" MAF -
$129.99 (This would put you closest to stock, minus restrictions, without tuning. I recommend verifying your AFRs on a dyno at the very least.)
Couplers - Slilcone reducer 2.75" to 3", you need 2 -
$12.99ea
MAFT Pro running Speed Density:
MAFT Pro -
$399.99
GM 3 bar MAP -
$74.99
GM IAT -
$13.99
Couplers - 0 - See note for intake.
http://www.siliconeintakes.com/prod...id=65&osCsid=3e3a44da51f08f823e2cf68e87b3c0a1
NOTE: Without an on board wideband you can NOT setup for a lean cruise or WOT AFR tracking!
Without running Speed/Density you can NOT use boost control in a NA-T setup... although if you're looking to use the MAFT Pro with a NA-T you shouldn't be looking at how to do it cheap.
