Project:: Reaper Begins!!!!
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
well we ran into some more wiring problems friday night. got those fixed....
saturday we finished it up had a PS leak and the radiator i got with my hydrofan assembly was cracked. i fixed the PS leak, swapped out radiators and then the tstat wasn't opening and the car was over heating. well i went and got a new 2J tstat and threw it in there and still no water flow....
hydro pump is dead......so all n all my weekend sucked bad. no mini meet and i didn't even get to drive the car.....GAY!!!
supra90turbo
shaeff is FTMFW!
32
MA, 01440
The Reaper said:
well i got her registered. i will be finishing it up tonight and driving it for the first time to a local Car meet. i can't wait
some other bastard in FL has the REAPER plate so i am COMPLETELY bummed about that. but owell
i will have video after this weekend im sure
Just abbreviate it. Is RAPER taken?
lol
The Reaper
Jan 10, 2006
1,909
Florida
HAHAHHAHAA
nah im cool with that now.... now im mad that the damn thing is still messed up car runs flawlessly tho nothing wrong with it other than water flow. so im stoked in THAT sense.
The Reaper
Jan 10, 2006
1,909
Florida
well i drove it to work today!!!!!! all is well. we got the 3 inch DP done last night it woke it up alot just going from stock open DP to 3 inch open DP. MAN what a difference lol...
so we'll be finishing up the back half of the exhaust and then its good to go!!!
The Reaper
Jan 10, 2006
1,909
Florida
oh shit i forgot about this thread. its all over the place in the 1J section LOL
well it was the tstat right now im driving it with no tstat and it flows perfect. im gonna buy a tstat this weekend and put it in.
car runs AWESOME tho. blown oil seal on turbo tho so it SMOKES LIKE SPYHUNTER!!!. sux but ive had a few races including one with a I/H/E C5 vette and was beating him until i hit boost cut in 3rd LOL
car is running awesome now!!!
The Reaper
Jan 10, 2006
1,909
Florida
hahaha thanks guys
just need to fix the leaking turbo oil seal. im back to driving my DD honda now just cause i can't stand it looking shitty while it idles. drives me up the wall....
now im saving for either a single kit or going 2J........hmmmmm
The Reaper
Jan 10, 2006
1,909
Florida
I Decided that i am going to Combine my multiple build threads and keep this one going only. which is why im bringing it back from the dead.
Well this past weekend Tissimo and i installed the single on my 1J
took awhile but finally got it.
Garrett T04S 60-1
Drego Manifold
Turbonetics 42mm Racegate
Ebay SSQV
Everything else is stock down to the IC PIPING!
Arriving at the lexus Dealership
Getting it up on the lift to remove custom exhaust to remove the twins
last shot of the gay twins on my 1J
Getting closer
Getting frustrated :aigo:
Removing the twins was GAY. such a PITA
Twins removed BYE BYE! :naughty:
Just for fun got a shot of my new twin Photon Blaster :biglaugh:
Test Fitting Drewgo's Manifold
Test Fitting the WG
Test Fitting the Turbo
A little more Test Fitting to figure out the path of the DP and Dump tube
More pics to come. a friend of mine who took these pics left at 9 on Saturday night. so no finished pics yet. just took the finished pics like an hour ago during a smoke break at work. will post em tomorrow!!
man the sound is awesome. 3 inch turbo back on Drewgo's manifold is NUTS!!!
man im glad i didn't sell this thing HAHAHAHAHA :aigo: :aigo: :aigo:
The Reaper
Jan 10, 2006
1,909
Florida
As many of you know i fried out 2 ECU's on my 1J. I'm over the 1J ECU's and have decided to go with an Aristo ECU and Aristo Harness. I got 440cc Injectors while i was at it and a New TiAL 38mm WG as well.
While i had the car apart for pulling the harness and removing the injectors i decided to paint a few things
Cam Cover and Plug Cover
and here is the Intake Manifold
Still need to paint the Lower runners and throttle body and then i will be done with that part.
i will post more pics as i get them with the harness installed and all that good stuff.
Looking so awesome now. How does it feel compared to the twins? Isn't your turbo about the same size as my gt35r?
That Photon Blaster looks more deadly than an SKS.
The Reaper
Jan 10, 2006
1,909
Florida
LMAO hell yea i blast lotsa hondas with it while crusin' in the supra
it feels WAY different than the twins my turbo is a 60-1 so its a 58mm
kotu100
1,899
Easton, Ma
nice single, hows it compare to the twins? dont ya think ya should rotate the BOV so that water wont get in and sit in there? besides its cool when ya blow off and all the dirt/leaves under the car blow out everywhere lol.
The Reaper
Jan 10, 2006
1,909
Florida
believe it or not but i haven't had a problem with water getting in it.
ofcourse i've only driven in rain once or twice. and even then the bov only opens between shifts. closed while driving
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Reaper - curious on how the 440cc injectors with the 60-1 turbo works. I have the same thing that I will eventually install. Are you keeping the boost under 14psi or you're looking to get more out of it? I know someone from celicasupra.com running the same setup and dynod at 433rwhp but I don't know what's controlling the boost and fuel. Let me know how this works for you if you don't mind.
The Reaper
Jan 10, 2006
1,909
Florida
Once its all put together and running i will push it higher than 14 psi.
i was running 14 psi on the stock 370's. it was hitting boost cut but was still pig rich.
60-1 wont put out A LOT of power. i expect 400whp on 18psi. which will be fine on 440's. my body connectors i need to finish the harness will be coming in, in a few days then they install takes place. i will keep you posted in this thread.
Edit:: to control boost i will just be using a MBC, and for fuel i have an SAFC2
