Project Git 'er done!: Stages 1 through5- ***14 YEARS....Approaching the finish line!!!***
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Well, I haven't been driving mine, but I have been trying to tune it.
Yesterday, I was busy messing with the idle, and I see that I'm suddenly leaking oil out of the front timing cover 'weep hole'.
So I pulled the rad(which needed to be tig'ed anyway), the covers and everything else. But I can't really tell whats been leaking.
There was just the slightest amount of oil, and you could see a teensy trace near the cams and the main. So, I just pulled tham all, and am going to swap them out tomorrow or the next day.
In the meantime, I have ordered a 5MGE oil pump pulley to replace the 7M unit. Now I just need to find someone who can fab the proper spacer.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Well, here's an update. I ordered mine from Toyotapartsonline. They later emailed me, saying that they couldn't find one, so i have cancelled my plan to swap out the gear. after talking to Toyotanos though, he says that he doesn't feel that its a necessary mod anyway, unless you have big cams and double springs.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Just the smallest of updates:
I began removing parts today to get the head off, and I'll probably finish up the removal tomorrow.
Here's the #1 & 2 spark plugs, when I pulled the coil assembly off:
I just don't get it. The valve covers are secure, and the galley plugs are sealed. I suspect that this head might be cracked somewhere.
I'm thinking of dropping my backup head off at the machine shop, to have it decked and get a valve job done...
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
For what its worth I always seem to get some oil in there. No matter how well I seal everything, some oil always ends up in there, either from the valve covers or the hex plugs. I've just come to accept it lol.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
So, I pulled the head this afternoon.
Both surfaces looked good, as did the gasket. In fact, the gasket looks perfect- none of the viton even broke.
However, it seemed like the entire surface of the gasket was oily, as was the deck surface, so I think that the oil passages weren't sealing,
and that oil was squeezing out between the head and block. Now I have to decide what i want to do-
Tear down the current head and have it checked by the shop, or build the backup head. Not sure, but I'll fiugre it out.
Grandavi
2,664
8
Calgary, Alberta, Canada
I'm trying to imagine how you could physically have an oily surface on the headgasket, both sides. Doesn't seem possible unless your head "floated" and I can't imagine that happening. I can imagine a hairline crack in the head that could allow the oil into 1 and 2, but that should be visible.
Gremlins... You gotta love them... So far I have had 3 of these types of issues where it didn't make logical sense. Luckily I had a team of mechanics spend a lot if time on it... So I didn't have to use my limited knowledge to troubleshoot. Hope it turns out being something small...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
Not sure what you mean by the third part in the middle of the valve cover?
As i mentioned, the valley cap bolts were all tight.
I used big drain plug gaskets for those.
It possible with the new fluid it could have leaked out and then in the time it sat the trail disappeared.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,281
71
Atlanta
No real exciting updates guys, sorry- I've been very lazy with the car lately.
I did reinstall the head with the new gasket, and found that previously, I had installed one of the cam seals with the lip folded over. Hoping that had something to do with the leak.
Also, I decided to have my injectors tested at FIC in FL, while everything was apart. They called me today, and said that they all flowed within 1% of each other with good patterns(@700cc), so they didn't recommend that I
pay for the full cleaning process. Very stand-up thing to do- saving me money.
I should get them back in the next few days, but it'll be at least another week till I touch the car again- have to go to NY for the weekend.
