Project Git 'er done!: Stages 1 through5- ***14 YEARS....Approaching the finish line!!!***
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Yup.
Doing some quick calculations, and assuming a normal amount of material removal by the machine shop,
a 3mm head gasket would put me aroun 8:1 CR.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
No, looks like i'll probably be sitting at my computer, ordering the Spec 2+ clutch when the apocalypse hits.
Knowing that i won't complete it before armageddon is a bit disappointing, but at least working on the Supra keeps me from getting too down about it.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Finally picked up my block/ crank from the machine shop:
Block- decked, linebored, honed:
Crank, polished, and balanced with the rotating assembly.
New squirter bolts:
Also done, was a check/ resize of the rods, and the machinist ordered/ supplied the ARP mains, and all bearings as well.
Next, I will install new oil pump shaft bearings, and paint the block prior to assembly.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
I still have to put one more coat and then clearcoat, but here's just a quick glimpse of it:
Primered:
Painted
ARP's test fitted
Still have to install the oil driveshaft bearings tomorrow, before I can do any real construction. But now I have *almost* everything I need to turn it into a longblock.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
So, I go to begin engine assembly today, and I realize that I can't really trust my old craftsman 1/2" drive torque wrench any more, as I had noticed that
when I set it to like 40 ft-lbs, it would just keep torquing, and not click. So I didn't want to use it without having it calibrated first. So I figure- hey, it's a craftsman,
they'll calibrate it. I go to Sears, and they send me to the sevice dept, and I tell the guy I need my TW calibrated. He says "uhh...we don't do that on premises, we send it to
a place in Texas that does it." I'm like, ok- how long's that gonna take? He says " about a week, and it costs $80. I'm like "What?!?" It didn't cost $80 new! :aigo:
So for $20 more, I just went over to the new wrenches, and picked one out:
Anyway, I got a little bit done after I finished painting and clear-coating the block.
Installed the freeze plugs, installed the oil driveshaft bearings(PITA), plasti-gauged the mains and installed the crank, and then assembled the pistons onto the rods.
Tomorrow, I will finish checking the ring gaps, install said rings, and install the pistons/ rods into the block.
Getting there. Only about $2,500 more to spend on the engine/tranny. Then on to the interior.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Thanks.
It's kind of a candy apple color from VHT. Had to order it because none of my local auto parts stores seemed to carry it.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Today's progress:
Next up is to install the oil pump driveshaft, oil pump, oil pan & front timing cover.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Well, if you use head bolts, you don't engage the threads as far down as they go.
Dunno if the studs thread down further, but using a bottom tap hits those dark scary places.
Oil driveshaft, oil pump and Arizona performance supply pipe, done.
Oh- forgot:
I also had my machine shop mill down the crankshaft pulley bolt to 45mm for the ATI superdamper:
Grandavi
2,664
8
Calgary, Alberta, Canada
In the Toyotaverse.... I bought 17 bolts for 75.00...
Meanwhile... Toyota's board members sit chuckling at the table.. as they relate how much those idiot North American devils paid for a bolt.
I believe it is a contest... no winner announced yet...
