HI, i decided to get the HSD coilover since they were supposed to be the same as stance. And they were easy for me to get them in canada. (got them from a canadian ebay seller , took 2 days to get at my door)
BUT i got a problem with the HSD coilover. it look like the rear coilovers was mount with the wrong black lower part. The sleeve where the shock is mount at the bottom is too large to be put on the supra tabs. The space available is 50mm max( with removing of the metal bushing). The HSD is 55mm. Its impossible to make it works. The front are ok and fit how they should (see pics)
I was reading here that a canadien guy from cambridge was telling that he was not able to put them. People were telling him to remove the metal bushing in the tabs but the guy still complaint that it was impossible. But he did not post pics or measurement of is problem so i did not care about it. Now i realise that the HSD canadian coilover may have a problem. My supra is a 1990. But every supra should have the same suspension specs. So look at the pics and you will see what i'm talking about. I already contact the seller but i want to know what you think about it.
EBAY AD LINK :http://www.ebay.com/itm/90-92-Toyot...Parts_Accessories&vxp=mtr&hash=item45f1fe0077
Waiting for your reply. thanks
Measurement of the rear coilover 55mm
Rear and front. you can see the difference
How i took measurement of the rear available space. You can see that i did not care of the bushing
Front correctly fit
Rear Koni that was in place. 48mm
![p1785692_1.jpg](https://www.supramania.com/images/pb_archive/p1785692_1.jpg)
![p1785692_2.jpg](https://www.supramania.com/images/pb_archive/p1785692_2.jpg)
![p1785692_3.jpg](https://www.supramania.com/images/pb_archive/p1785692_3.jpg)
Front correctly fit
![p1785692_4.jpg](https://www.supramania.com/images/pb_archive/p1785692_4.jpg)
![p1785692_5.jpg](https://www.supramania.com/images/pb_archive/p1785692_5.jpg)
