PPI Amps
killarb634
Jersey's here
I got two precision power amps sitting here but i need the clips taht connect into the amp? Does anyone have any idea on where to go and get these clip? They are the clips that the speaker wires and remote wires connect too. The amps are PPI AX400 AND PPI 2075AM if that can help and have you answer my questions.. Thanks alot
Brian
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
You'll likely have to pull them apart, desolder the connectors, and solder in some new ones from an electronics supply shop. Up here, I would buy from Active Electronics, but you'll have to find one local to you...
The chances of getting the original connected are pretty much slim to none.
Alternatively, you could take them into any car audio repair shop and ask them to do the same, probably would cost you under $100 each.
killarb634
Jersey's here
I was thinking. Cant i just take the bullet connectors and crimp them on to each piece of amp and run wire fom each one to the new speaker, remote, etc.
